Gigabyte Sabre 15 Laptop RAM Replacement
      • Disconnect the laptop charger. Close the lid and turn the laptop over so that it is resting on its lid on your surface.
      Ask FixBot
    1. Gigabyte Sabre 15 Laptop RAM Replacement, Remove securing screws: step 2, image 1 of 1
      • Using the iFixit screwdriver with a 000 tip, remove the 12 screws from around the base
      Ask FixBot
      • There are two sliding switches on the battery that both been to be in the open position to allow the battery to be removed
      • The left hand switch is spring-loaded and will need to be pushed to the right and held
      • The right hand switch is a simple mechanical switch, slide it to the left to unlock
      • Use a finger nail to get in the recess to lift the front edge of the battery up
      • Rotate the battery as though it is hinged until it points straight up, then lift the battery away
      Ask FixBot
    2. Gigabyte Sabre 15 Laptop RAM Replacement, Detach the base: step 4, image 1 of 1
      • The first time it comes to removing the base of the laptop is very intimidating - it's well secured and doesn't seem to give easily
      • I used a Jimmy tool, however any of the prying tools will work well, you just need something with a reasonably fine tip / head on it.
      • Start between two connectors (the two USB-A ports on the right-hand side as shown in the image), gently insert the Jimmy in the seam where the top- and bottom-lids meet between the two connectors and gently twist to help get the Jimmy deeper.
      • You'll only need to be in a few millimetres before the chassis will split apart.
      • Then work your way around the entire perimeter.
      Ask FixBot
    3. Gigabyte Sabre 15 Laptop RAM Replacement, Complete: step 5, image 1 of 1
      • Job done!
      Ask FixBot
      • There are a pair of slots for RAM, these are located in the lower-middle area of the motherboard
      Ask FixBot
      • Each memory module has a pair of retaining arms that clip in to each side. In order to remove an existing module, or to easily get a module in these arms need to be released.
      • If there is already a memory module in, then gently press the module down slightly and use your thumbnail to gentle pry the arm away by just a millimeter or two
      • Then release the pressure of the memory module - you will see that the arm is now out (and below) the retaining slot.
      • Repeat this for the opposite arm (you'll need to do both arms simultaneously!
      • Once both arms are clear, the memory module will want to naturally pop-up
      • The module can now be removed
      Ask FixBot
Chris
452 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 89
