Gigabyte RTX 3060 GPU Fan Replacement
Views: 16K
View statistics:
Past 24 Hours:
25
Past 7 Days:
196
Past 30 Days:
823
All Time:
15,507
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide is designed to aid individuals in replacing the GPU fan on the Gigabyte RTX 3060 Graphics Card. It includes various considerations that might be relevant to different repair scenarios. This guide addresses common problems associated with GPU fans, such as damaged fan blades or a malfunctioning fan unit connected to the graphics card. To carry out this repair, no specialized skills or tools are necessary, except for the Phillips #00 screwdriver mentioned in this guide.
Ensure that your workspace is tidy and free of clutter before you start the repair.
Tools
    1. Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: step 1, image 1 of 3 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: step 1, image 2 of 3 Gigabyte RTX 3060 GPU Fan Replacement, GPU Fan: step 1, image 3 of 3
      • Remove the four springs screws attached to the thermal plate on the GPU using a Phillips #00 screwdriver.
      • Remove the two screws from the right side using a Phillips #00 screwdriver.
      • Remove the two screws from the left side using a Phillips #00 screwdriver.
      Ask FixBot
    2. Gigabyte RTX 3060 GPU Fan Replacement: step 2, image 1 of 3 Gigabyte RTX 3060 GPU Fan Replacement: step 2, image 2 of 3 Gigabyte RTX 3060 GPU Fan Replacement: step 2, image 3 of 3
      • Lift the backplate off after the screws are removed.
      • You will notice both sides of the card have a cable holding the cover and the main GPU board.
      • Carefully remove the connector at the top of the GPU (the side with GEFORCE RTX like on the picture) connecting the GPU board and the fan cover.
      Ask FixBot
    3. Gigabyte RTX 3060 GPU Fan Replacement: step 3, image 1 of 2 Gigabyte RTX 3060 GPU Fan Replacement: step 3, image 2 of 2
      • Flip over the GPU cover.
      • Remove the four screws using a Phillips #00 screwdriver.
      Ask FixBot
    4. Gigabyte RTX 3060 GPU Fan Replacement: step 4, image 1 of 2 Gigabyte RTX 3060 GPU Fan Replacement: step 4, image 2 of 2
      • Set the thermal system to the side.
      • Flip over the GPU cover with the fans and find the fan that needs to be replaced.
      • There are three screws underneath the fan blades. Look at the second picture as a reference for one of the screws. Remove all three using a Phillips #00 screwdriver.
      Ask FixBot
    5. Gigabyte RTX 3060 GPU Fan Replacement: step 5, image 1 of 2 Gigabyte RTX 3060 GPU Fan Replacement: step 5, image 2 of 2
      • Remove the connector associated with the fan.
      • Pull the fan out with its connector cable intact.
      Ask FixBot
    6. Gigabyte RTX 3060 GPU Fan Replacement: step 6, image 1 of 1
      • Grab your replacement fan for the Gigabyte RTX 3060.
      • The repair can be completed with the replacement fan by reversing the steps previously shown.
      Ask FixBot
5 other people completed this guide.
sanskar1016
277 Reputation
1 Guide authored
1 Guide Comment
и потом через время карта сломается. это написано делитантом для делитантов. ни слова о замене термопасты. собрать в обратном порядке, и не заменить термопасту, это трешь. не рекомендую это никому.
Николай Тиссин - Reply Share
Past 24 Hours: 25
Past 7 Days: 196
Past 30 Days: 823
All Time: 15,507
