Gigabyte P34G Solid State Drive Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
94
All Time:
2,288
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The solid state drive stores some of the computer's files and has limited space. Replacement of the solid state drive is necessary if it is broken or there is no space left.
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds.
Parts
Tools
    1. Gigabyte P34G Solid State Drive Replacement, Solid State Drive: step 1, image 1 of 1
      • Remove all 15 marked screws on the underside of the laptop using a #0 screwdriver.
      • There are three different sized screws.
      • x1 9.8mm Screw
      • x8 5.6mm Screws
      • x6 5.0mm Screws
      • Divide the screws by size and save them in a safe space for reassembly later.
      Ask FixBot
    2. Gigabyte P34G Solid State Drive Replacement: step 2, image 1 of 1
      • Unscrew the marked 4.5mm screw with a #0 screwdriver.
      • Set the screw aside to use for reassembly after replacing the solid state drive.
      Ask FixBot
    3. Gigabyte P34G Solid State Drive Replacement: step 3, image 1 of 1
      • Carefully pull the solid state drive in the direction shown to disconnect it from the port.
      Ask FixBot
yeunghayden
841 Reputation
6 Guides authored
Cal Poly, Team 8-1, Regan Spring 2015 Member of Cal Poly, Team 8-1, Regan Spring 2015
CPSU-REGAN-S15S8G1
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 94
All Time: 2,288
