Introduction
Go to step 1 ↓The laptop uses RAM to read and write data and to perform basic operations. RAM may need to be replaced or added overtime for the laptop to be at optimal performance.
Make sure you are grounded before starting. To ground yourself, simply touch a metal object that is in contact with the floor for a few seconds.
Unscrew the single 9.8mm screw on the underside of the laptop using a #0 screwdriver.
2 other people completed this guide.
