Gigabyte Aero 15x Disassembly
Views: 16K
View statistics:
Past 24 Hours:
6
Past 7 Days:
38
Past 30 Days:
201
All Time:
15,653
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a guide for removing the back cover on the Gigabyte Aero 15x for upgrades or for maintenance.
To start, shut down your computer.
Tools
    1. Gigabyte Aero 15x Disassembly, Remove the screws: step 1, image 1 of 2 Gigabyte Aero 15x Disassembly, Remove the screws: step 1, image 2 of 2
      • Using a Torx T6, remove the 13 screws. Remember their exact spot because the 3 in the "middle" are longer (see picture 2).
      • These 3 screws are hidden by a black sticker. Simply push down on the screwdriver to catch the indentation of the screw head.
      Ask FixBot
    2. Gigabyte Aero 15x Disassembly, Unclip the lower case: step 2, image 1 of 3 Gigabyte Aero 15x Disassembly, Unclip the lower case: step 2, image 2 of 3 Gigabyte Aero 15x Disassembly, Unclip the lower case: step 2, image 3 of 3
      • Using plastic tools, start unclipping the back from the body. Insert one tool and, using a second, gently follow the perimeter.
      • Do not insert your tool too deeply, to avoid snagging a clip.
      • Do not unclip the back face fully; only the front and the 2 sides. You can nevertheless detach the 4 corners.
      • Photo 3 shows the location of the snap fits to disengage in green. In red, these are the "clutch hinges" of the case (see next step).
      Ask FixBot
    3. Gigabyte Aero 15x Disassembly, Remove the lower case: step 3, image 1 of 2 Gigabyte Aero 15x Disassembly, Remove the lower case: step 3, image 2 of 2
      • Before removing the hood, remember that it is held by 2 aluminum rails at the back (hinge side).
      • Remove the cover starting at the front two corners. Lift up at those corners.
      • Do not force if you encounter a hard spot; the metal could bend. Use leverage with a small tool because the cover has no ribbon cables.
      Ask FixBot
    4. Gigabyte Aero 15x Disassembly, You're finished!: step 4, image 1 of 1
      • Congratulations!
      Ask FixBot
To reassemble, follow these steps in reverse order.
4 other people completed this guide.
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Kev
267 Reputation
1 Guide authored
2 Guide Comments
Thank you for writing this! I really appreciate it
John O'Reilly - Reply Share
There are 2 screws that are slightly shorter and 2 others slightly longer than the rest of the bunch.
Locky L - Reply Share
Past 24 Hours: 6
Past 7 Days: 38
Past 30 Days: 201
All Time: 15,653
