Giant Reign 2 Wheel Spoke Replacement
    1. Giant Reign 2 Wheel Spoke Replacement, Hex Screws: step 1, image 1 of 1
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      Ask FixBot
    2. Giant Reign 2 Wheel Spoke Replacement, Axle Screw: step 2, image 1 of 2 Giant Reign 2 Wheel Spoke Replacement, Axle Screw: step 2, image 2 of 2
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      Ask FixBot
    3. Giant Reign 2 Wheel Spoke Replacement: step 3, image 1 of 1
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      Ask FixBot
    4. Giant Reign 2 Wheel Spoke Replacement, Front Wheel: step 4, image 1 of 1
      • Pull the wheel from the fork.
      Ask FixBot
    1. Giant Reign 2 Wheel Spoke Replacement, Tire Valve: step 5, image 1 of 3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: step 5, image 2 of 3 Giant Reign 2 Wheel Spoke Replacement, Tire Valve: step 5, image 3 of 3
      • Twist and pull off the cap covering the tire valve
      • Twist off the spacer that holds the valve in place.
      • Push valve in toward wheel to release air pressure.
      Ask FixBot
    2. Giant Reign 2 Wheel Spoke Replacement, Tire Rim: step 6, image 1 of 3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: step 6, image 2 of 3 Giant Reign 2 Wheel Spoke Replacement, Tire Rim: step 6, image 3 of 3
      • Insert one tire lever between the tire and the rim.
      • Push down on the tire lever until the edge of the tire is higher than the edge of the rim.
      • Insert a second tire lever next to the first.
      • Slowly slide one tire lever around the rim until the tire is released from the rim.
      Ask FixBot
    3. Giant Reign 2 Wheel Spoke Replacement, Tire Tube: step 7, image 1 of 1
      • Using your hand, pull the tube completely out of the tire.
      Ask FixBot
    4. Giant Reign 2 Wheel Spoke Replacement, Brake Rotor: step 8, image 1 of 1
      • Use an 8mm Allen wrench to unscrew the 6 (4x10mm) screws on the brake rotor.
      • Pull brake rotors off both sides of the wheel.
      Ask FixBot
    5. Giant Reign 2 Wheel Spoke Replacement, Tire: step 9, image 1 of 1
      • Pull the tire from the rim.
      Ask FixBot
    6. Giant Reign 2 Wheel Spoke Replacement, Rim Tape: step 10, image 1 of 1
      • Using a tire lever, push the rim tape aside to reveal the spoke nipple.
      • Using your fingers, pull off the old spoke nipple.
      Ask FixBot
    7. Giant Reign 2 Wheel Spoke Replacement, Wheel Spoke: step 11, image 1 of 1
      • Push out the old spoke from the hub.
      Ask FixBot
    8. Giant Reign 2 Wheel Spoke Replacement: step 12, image 1 of 2 Giant Reign 2 Wheel Spoke Replacement: step 12, image 2 of 2
      • Insert a new 250mm spoke into the hub.
      • Align the spoke with the spoke nipple in the rim.
      • Try to keep the spoke as straight as possible when threading it around the other spokes. Slight bends will be taken out when it is tightened.
      Ask FixBot
    9. Giant Reign 2 Wheel Spoke Replacement: step 13, image 1 of 1
      • Using an SW-1 spoke wrench, tighten the spoke.
      Ask FixBot
Sterling Grande
148 Reputation
4 Guides authored
Cal Poly, Team 9-14, Amido Fall 2012 Member of Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 32
All Time: 2,868
