Up to 20% off select tools
Giant Reign 2 Headset Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
105
All Time:
5,093
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 10
10 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
Proper maintenance of the Giant Reign 2 bicycle includes installation and lubrication of a new headset. This guide will clearly show you how to perform this maintenance quickly and safely, extending the life of your bike.
    1. Giant Reign 2 Headset Replacement, Hex Screws: step 1, image 1 of 1
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      Ask FixBot
    2. Giant Reign 2 Headset Replacement, Axle Screw: step 2, image 1 of 2 Giant Reign 2 Headset Replacement, Axle Screw: step 2, image 2 of 2
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      Ask FixBot
    3. Giant Reign 2 Headset Replacement: step 3, image 1 of 1
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      Ask FixBot
    4. Giant Reign 2 Headset Replacement, Front Wheel: step 4, image 1 of 1
      • Pull the wheel from the fork.
      Ask FixBot
    1. Giant Reign 2 Headset Replacement, Headset: step 5, image 1 of 2 Giant Reign 2 Headset Replacement, Headset: step 5, image 2 of 2
      • Using the 8mm Allen wrench, unscrew 2 (32mm) screws to release the brake calipers from the fork.
      • If necessary use wire cutters to release zip ties attaching cables to the forks.
      Ask FixBot
    2. Giant Reign 2 Headset Replacement: step 6, image 1 of 3 Giant Reign 2 Headset Replacement: step 6, image 2 of 3 Giant Reign 2 Headset Replacement: step 6, image 3 of 3
      • Using the 8mm Allen wrench, unscrew the 30mm head screw located on top of the steam.
      • Using the 4mm Allen wrench, loosen the side screw on both sides.
      • Lift off the handlebar.
      • Hang the handlebar gently from the cables. Do not pull the cables as you may damage the brake/derailleur lines.
      Ask FixBot
    3. Giant Reign 2 Headset Replacement: step 7, image 1 of 3 Giant Reign 2 Headset Replacement: step 7, image 2 of 3 Giant Reign 2 Headset Replacement: step 7, image 3 of 3
      • Slide off the spacers.
      • Lift off the seal.
      Ask FixBot
    4. Giant Reign 2 Headset Replacement: step 8, image 1 of 1
      • Slide the fork out of the casing.
      Ask FixBot
    5. Giant Reign 2 Headset Replacement: step 9, image 1 of 1
      • Using your fingers, pry the bearings from the top and bottom of the headset.
      Ask FixBot
    6. Giant Reign 2 Headset Replacement: step 10, image 1 of 1
      • Apply WD-40 to both ends of the headset and bearings.
      • Dry headset and bearings with paper towels.
      • Repeat as necessary until clean.
      Ask FixBot
    7. Giant Reign 2 Headset Replacement: step 11, image 1 of 2 Giant Reign 2 Headset Replacement: step 11, image 2 of 2
      • Using your finger, apply all-purpose lube to the bearings and each end of the headset.
      • Insert the bearings into the headset with the beveled side facing into the headset.
      Ask FixBot
Author
with
Sterling Grande
148 Reputation
4 Guides authored
Cal Poly, Team 9-14, Amido Fall 2012 Member of Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 105
All Time: 5,093
