Giant Reign 2 Front Wheel Replacement
Views: 15K
View statistics:
Past 24 Hours:
5
Past 7 Days:
38
Past 30 Days:
168
All Time:
15,457
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Removing the front wheel of the Giant Reign 2 is a common first step for other repair guides. This guide will clearly show you how to use simple tools to remove the front wheel quickly and safely.
Tools
    1. Giant Reign 2 Front Wheel Replacement, Hex Screws: step 1, image 1 of 1
      • Using the 4mm Allen wrench, partially unscrew the 4 (22mm) hex screws on the front of the axle casing to allow the axle to slide freely.
      Ask FixBot
    2. Giant Reign 2 Front Wheel Replacement, Axle Screw: step 2, image 1 of 2 Giant Reign 2 Front Wheel Replacement, Axle Screw: step 2, image 2 of 2
      • Using the 8mm Allen wrench, loosen the axle screw until 1/2 of the axle screw is visible.
      • Push the axle screw to reveal the axle rod on the other side.
      Ask FixBot
    3. Giant Reign 2 Front Wheel Replacement: step 3, image 1 of 1
      • Using the Allen wrench, finish unscrewing the axle screw and pull it out.
      • Hold the wheel when pulling out the axle rod so that the bike does not fall.
      Ask FixBot
    4. Giant Reign 2 Front Wheel Replacement, Front Wheel: step 4, image 1 of 1
      • Pull the wheel from the fork.
      Ask FixBot
2 other people completed this guide.
Andrew Krasts
302 Reputation
2 Guides authored
Cal Poly, Team 9-14, Amido Fall 2012 Member of Cal Poly, Team 9-14, Amido Fall 2012
CPSU-AMIDO-F12S9G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 168
All Time: 15,457
