Up to 20% off select tools
Ghost Longboard Wheel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
52
All Time:
850
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to replace the damaged, warped, or dented wheels on your Ghost Longboard. This guide requires minimal skill and no prior experience. It is especially useful if your board is not as fast as it used to be, it has become more difficult to turn, or it does not coast for as long as you would like it to. the ghost longboard wheels are easy to replace.
    1. Ghost Longboard Wheel Replacement, Wheel: step 1, image 1 of 1
      • Using a 15 mm socket wrench, unscrew the axle nut.
      Ask FixBot
    2. Ghost Longboard Wheel Replacement: step 2, image 1 of 1
      • Using your fingers, remove the axle nut from the axle.
      Ask FixBot
    3. Ghost Longboard Wheel Replacement: step 3, image 1 of 1
      • Remove the washer from the axle.
      Ask FixBot
    4. Ghost Longboard Wheel Replacement: step 4, image 1 of 1
      • Remove the wheel from the axle.
      Ask FixBot
    5. Ghost Longboard Wheel Replacement: step 5, image 1 of 1
      • Remove the second washer from the axle.
      Ask FixBot
    6. Ghost Longboard Wheel Replacement: step 6, image 1 of 1
      • Slide a new washer onto the axle.
      Ask FixBot
    7. Ghost Longboard Wheel Replacement: step 7, image 1 of 2 Ghost Longboard Wheel Replacement: step 7, image 2 of 2
      • Place the new wheel on the axle.
      • Be sure to position the flat side of the wheel so it is facing inward.
      Ask FixBot
    8. Ghost Longboard Wheel Replacement: step 8, image 1 of 1
      • Place a second washer on the axle exterior to the wheel.
      Ask FixBot
    9. Ghost Longboard Wheel Replacement: step 9, image 1 of 1
      • Place an axle nut on the axle.
      Ask FixBot
    10. Ghost Longboard Wheel Replacement: step 10, image 1 of 1
      • Using a 15 mm socket wrench, tighten the axle nut.
      • Be sure to tighten the axle nut enough to prevent the wheel from wobbling, but not so tight as to prohibit the wheel from spinning freely.
      Ask FixBot
Repeat these steps on the three remaining wheels.
Author
with
Patricia Roux
184 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 850
