Up to 20% off select tools
Genesis II CSS-315 Ignitor Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
89
All Time:
1,588
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 50 minutes
Difficulty: Easy
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
    1. Genesis II CSS-315 Ignitor Replacement, Ignitor: step 1, image 1 of 2 Genesis II CSS-315 Ignitor Replacement, Ignitor: step 1, image 2 of 2
      • Be sure the grill is turned off before beginning this guide.
      • Remove all of the control knobs.
      • The amount of knobs may vary depending on the grill.
      Ask FixBot
    2. Genesis II CSS-315 Ignitor Replacement: step 2, image 1 of 2 Genesis II CSS-315 Ignitor Replacement: step 2, image 2 of 2
      • Remove the two 19 mm screws below the control knob panel using a Phillips #3 screwdriver.
      Ask FixBot
    3. Genesis II CSS-315 Ignitor Replacement: step 3, image 1 of 2 Genesis II CSS-315 Ignitor Replacement: step 3, image 2 of 2
      • Push up on the front panel, and pull it up above the grill.
      • Potential for device damage: The ignitor is connected to the front panel, so do not pull too hard.
      Ask FixBot
    4. Genesis II CSS-315 Ignitor Replacement: step 4, image 1 of 2 Genesis II CSS-315 Ignitor Replacement: step 4, image 2 of 2
      • Disconnect the cables from the ignitor.
      Ask FixBot
    5. Genesis II CSS-315 Ignitor Replacement: step 5, image 1 of 1
      • Pinch the two ends of the ignitor and remove the ignitor from the front panel.
      Ask FixBot
    6. Genesis II CSS-315 Ignitor Replacement: step 6, image 1 of 1
      • Have the new ignitor on hand, and make sure that the clips on the side are in good condition.
      • Ensure that the pins at the end are straight and not bent.
      Ask FixBot
    7. Genesis II CSS-315 Ignitor Replacement: step 7, image 1 of 3 Genesis II CSS-315 Ignitor Replacement: step 7, image 2 of 3 Genesis II CSS-315 Ignitor Replacement: step 7, image 3 of 3
      • Put the new ignitor into the socket.
      • Press down evenly until it is secure.
      Ask FixBot
    8. Genesis II CSS-315 Ignitor Replacement: step 8, image 1 of 1
      • Connect the white cables to the ignitor.
      Ask FixBot
    9. Genesis II CSS-315 Ignitor Replacement: step 9, image 1 of 2 Genesis II CSS-315 Ignitor Replacement: step 9, image 2 of 2
      • Make sure any and all cables are separated from the fire box (the bottom of the grill).
      • Slot the panel back on the grill and then push downward.
      • The fire box is the part of the grill that gets really hot, and this can damage the cables.
      Ask FixBot
    10. Genesis II CSS-315 Ignitor Replacement: step 10, image 1 of 1
      • Make sure the holes match and reinsert the screws from Step 2 using a Phillips #3 screwdriver.
      • If the holes do not match up, you may have to gently push or pull the front plastic panel.
      Ask FixBot
    11. Genesis II CSS-315 Ignitor Replacement: step 11, image 1 of 2 Genesis II CSS-315 Ignitor Replacement: step 11, image 2 of 2
      • Add the control knobs, and slot them into place.
      Ask FixBot
Finish Line
Author
with
Carlos Castro Paguaga
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 89
All Time: 1,588
