Up to 20% off select tools
Generic DualShock 2 Cable Pinout
Views: 13K
View statistics:
Past 24 Hours:
9
Past 7 Days:
95
Past 30 Days:
387
All Time:
12,847
Comments: 6
6 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
I have this DualShock controller that had broken wires, but I couldn't find how to connect each cable on this board that seems to be a CHS-401, so I went to the trouble of finding how and here it is.
Hope to help somebody.
    1. Generic DualShock 2 Cable Pinout, DualShock 2 Disassembly: step 1, image 1 of 2 Generic DualShock 2 Cable Pinout, DualShock 2 Disassembly: step 1, image 2 of 2
      • First, check that the connection port of your controller (whether wireless or not) has all the pins.
      • If you have a wired controller (a controller with a cable that connects directly to your console) try bending it in different directions. This may reconnect broken connections within the controller cable and could be a temporary fix.
      Ask FixBot
    2. Generic DualShock 2 Cable Pinout: step 2, image 1 of 2 Generic DualShock 2 Cable Pinout: step 2, image 2 of 2
      • Flip Over Controller and remove all 6 screws from the bottom of the controller.
      Ask FixBot
    3. Generic DualShock 2 Cable Pinout: step 3, image 1 of 2 Generic DualShock 2 Cable Pinout: step 3, image 2 of 2
      • Once the screws are removed, carefully pry the controller open with your hands.
      • Remove the screw holding the circuit board in place.
      Ask FixBot
    4. Generic DualShock 2 Cable Pinout: step 4, image 1 of 1
      • Carefully remove the circuit board from the front cover of the controller.
      Ask FixBot
    5. Generic DualShock 2 Cable Pinout: step 5, image 1 of 1
      • Analyze the rubber pads for any debris that may be getting in the way of the black pads. These make an electrical connection on the pad and may not be contacting properly.
      Ask FixBot
    6. Generic DualShock 2 Cable Pinout: step 6, image 1 of 1
      • Examine the flexible trigger board itself for any dirt or debris that could get in the rubber button pad's way.
      Ask FixBot
    7. Generic DualShock 2 Cable Pinout: step 7, image 1 of 1
      • Check the connection of the flexible trigger board to the main circuit board of your controller.
      Ask FixBot
    8. Generic DualShock 2 Cable Pinout: step 8, image 1 of 1
      • If the previous steps are all covered and you are still facing difficulties in getting your buttons to work, consider replacing the main circuit board or flexible trigger board.
      Ask FixBot
    9. Generic DualShock 2 Cable Pinout: step 9, image 1 of 1
      • Reverse the disassembly steps until the controller is back to its original state. Plug the controller into the console and test whether the fix worked.
      Ask FixBot
    1. Generic DualShock 2 Cable Pinout, Cable Color And Order: step 10, image 1 of 2 Generic DualShock 2 Cable Pinout, Cable Color And Order: step 10, image 2 of 2
      • Here it is how it should be connected.
      Ask FixBot
3 other people completed this guide.
Author
with
Bruno Melo
178 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 95
Past 30 Days: 387
All Time: 12,847
