General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement
  1. General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the cable end cover: step 1, image 1 of 2 General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the cable end cover: step 1, image 2 of 2
    • Turn off the drain cleaner and disconnect it from power before beginning any maintenance.
    • Slide the rubber cable cover off of the end of the cable.
    Ask FixBot
  2. General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Loosen the front assembly screws: step 2, image 1 of 1
    • Use a flathead screwdriver to loosen the three screws around the edge of the front assembly.
    Ask FixBot
  3. General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the front assembly: step 3, image 1 of 3 General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the front assembly: step 3, image 2 of 3 General Wire Drain Cleaner RSVD 2014 Front Assembly Replacement, Remove the front assembly: step 3, image 3 of 3
    • Pull the front assembly off of the drain cleaner and slide it over the cable to remove it.
    • During reassembly, make sure the three screws on the front assembly line up with the slots on both the metal cable container back and the plastic cable container.
    Ask FixBot
3 other people completed this guide.
Adam O'Camb
223,790 Reputation
416 Guides authored
1 Guide Comment
what is the order number for the plastic cartrig refill
ROBERT - Reply Share
Past 24 Hours: 4
Past 7 Days: 12
Past 30 Days: 62
All Time: 2,196
