General Wire Drain Cleaner RSVD 2014 Cable Replacement
  1. General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the cable end cover: step 1, image 1 of 2 General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the cable end cover: step 1, image 2 of 2
    • Turn off the drain cleaner and disconnect it from power before beginning any maintenance.
    • Slide the rubber cable cover off of the end of the cable.
    Ask FixBot
  2. General Wire Drain Cleaner RSVD 2014 Cable Replacement, Loosen the front assembly screws: step 2, image 1 of 1
    • Use a flathead screwdriver to loosen the three screws around the edge of the front assembly.
    Ask FixBot
  3. General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the front assembly: step 3, image 1 of 3 General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the front assembly: step 3, image 2 of 3 General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the front assembly: step 3, image 3 of 3
    • Pull the front assembly off of the drain cleaner and slide it over the cable to remove it.
    • During reassembly, make sure the three screws on the front assembly line up with the slots on both the metal cable container back and the plastic cable container.
    Ask FixBot
  4. General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the cable container: step 4, image 1 of 2 General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the cable container: step 4, image 2 of 2
    • Slide the plastic cable container out of the metal container back.
    Ask FixBot
  5. General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the cable: step 5, image 1 of 3 General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the cable: step 5, image 2 of 3 General Wire Drain Cleaner RSVD 2014 Cable Replacement, Remove the cable: step 5, image 3 of 3
    • Pull the cable out of the plastic cable container.
    • During reassembly, make sure to insert the end of the cable with the hook (as shown in the third photo) first, then coil the rest of the cable into the container in a counter-clockwise fashion.
    Ask FixBot
6 other people completed this guide.
Adam O'Camb
223,718 Reputation
416 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 23
Past 30 Days: 128
All Time: 4,942
