General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement
  1. General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement, Motor Assembly: step 1, image 1 of 1
    • Before you begin, make sure the drain cleaner is disconnected from power.
    • Loosen the belt guard knob enough to be able to slide the belt guard toward the front of the drain cleaner.
  2. General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement: step 2, image 1 of 1
    • Slide the belt guard toward the front of the drain cleaner and off of the motor.
  3. General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement: step 3, image 1 of 3 General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement: step 3, image 2 of 3 General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement: step 3, image 3 of 3
    • Push down on the motor to take tension off of the belt.
    • The motor mount is spring-loaded to keep tension on the belt.
    • Lift the belt off of the motor pulley and remove it from the motor.
  4. General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement: step 4, image 1 of 2 General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement: step 4, image 2 of 2
    • Use two 1/2 inch wrenches to remove the four nut and bolt sets securing the motor to the drain cleaner.
    • During reassembly, make sure that the belt pulley on the motor is lined up with the belt groove on the cage before tightening the bolts.
  5. General Pipe Cleaners Drain Cleaner EJB 2014 Motor Assembly Replacement: step 5, image 1 of 1
    • Remove the motor assembly.
2 other people completed this guide.
Adam O'Camb
222,698 Reputation
416 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 56
All Time: 2,939
