General Electric Create Jason Wu LCD Screen Replacement
    1. General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: step 1, image 1 of 3 General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: step 1, image 2 of 3 General Electric Create Jason Wu LCD Screen Replacement, General Electric Create Jason Wu Casing Disassembly: step 1, image 3 of 3
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Ask FixBot
    2. General Electric Create Jason Wu LCD Screen Replacement: step 2, image 1 of 2 General Electric Create Jason Wu LCD Screen Replacement: step 2, image 2 of 2
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Ask FixBot
    3. General Electric Create Jason Wu LCD Screen Replacement: step 3, image 1 of 3 General Electric Create Jason Wu LCD Screen Replacement: step 3, image 2 of 3 General Electric Create Jason Wu LCD Screen Replacement: step 3, image 3 of 3
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Ask FixBot
    4. General Electric Create Jason Wu LCD Screen Replacement: step 4, image 1 of 3 General Electric Create Jason Wu LCD Screen Replacement: step 4, image 2 of 3 General Electric Create Jason Wu LCD Screen Replacement: step 4, image 3 of 3
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Ask FixBot
    1. General Electric Create Jason Wu LCD Screen Replacement, LCD Screen: step 5, image 1 of 2 General Electric Create Jason Wu LCD Screen Replacement, LCD Screen: step 5, image 2 of 2
      • With the back casing that you just separated from the camera, use your finger to push the LCD screen from the frame.
      • The LCD screen is secured to the frame with a thin layer of adhesive, not much force is required to removed the screen from the back casing.
      • Before replacing the back casing with the new LCD screen, please be sure it is secured into the casing with new adhesive.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 34
All Time: 529
