Up to 20% off select tools
General Electric Create Jason Wu Casing Disassembly
View statistics:
Past 24 Hours:
5
Past 7 Days:
19
Past 30 Days:
88
All Time:
862
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide will show how to carefully remove the front and back plastic casing that surrounds the camera.
    1. General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: step 1, image 1 of 3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: step 1, image 2 of 3 General Electric Create Jason Wu Casing Disassembly, General Electric Create Jason Wu Casing Disassembly: step 1, image 3 of 3
      • Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
      • These screws were missing in our example. These screws should have been small Phillips PH000 screws 1.5mm in length.
      • These screws are very small. To keep from losing any pieces, place all small metals on a magnetic project mat.
      Ask FixBot
    2. General Electric Create Jason Wu Casing Disassembly: step 2, image 1 of 2 General Electric Create Jason Wu Casing Disassembly: step 2, image 2 of 2
      • After the screws are removed, pull the front casing up and away from the camera.
      • If the casing is difficult to remove, use a plastic opening tool to gently pry up on the front as shown.
      Ask FixBot
    3. General Electric Create Jason Wu Casing Disassembly: step 3, image 1 of 3 General Electric Create Jason Wu Casing Disassembly: step 3, image 2 of 3 General Electric Create Jason Wu Casing Disassembly: step 3, image 3 of 3
      • Using your hands or an opening tool, pry off the silver frame, taking special care at the top of the camera where the buttons are as it is a little harder to pry off.
      • If the back casing is loose from the camera body, it may be easier to perform step 4 first, then accomplish this step. Proceed as your unit allows.
      Ask FixBot
    4. General Electric Create Jason Wu Casing Disassembly: step 4, image 1 of 3 General Electric Create Jason Wu Casing Disassembly: step 4, image 2 of 3 General Electric Create Jason Wu Casing Disassembly: step 4, image 3 of 3
      • The last part of the casing to disconnect is the back that houses the LCD screen.
      • The screen is attached by a connection ribbon. Gently pull the casing and screen away from the camera body to disconnect the casing.
      • The LCD screen is held onto the back casing by a small amount of adhesive. This may come loose during this process. Do not worry if they become separated.
      • This plug and the connection ribbon are fragile, try not to tear the connection ribbon when disconnecting.
      Ask FixBot
2 other people completed this guide.
Author
with
Kylan Hennessy
573 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 88
All Time: 862
