Up to 20% off select tools
GeeksPhone Keon Antenna Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
84
All Time:
708
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
After calling your service provider, if you are having bad cellular reception or other service issues, use this guide to replace the antenna.
    1. GeeksPhone Keon  Antenna Replacement, Battery: step 1, image 1 of 2 GeeksPhone Keon  Antenna Replacement, Battery: step 1, image 2 of 2
      • Insert the plastic opening tool into the seam between the front of the device and the rear cover.
      • Slide the plastic opening tool from the bottom of the phone to the top.
      • Use the plastic opening tool to free all the clips attached to the phone.
      Ask FixBot
    2. GeeksPhone Keon  Antenna Replacement: step 2, image 1 of 1
      • Lift the cover away from the phone.
      Ask FixBot
    3. GeeksPhone Keon  Antenna Replacement: step 3, image 1 of 1
      • Insert the plastic opening tool into the groove between the bottom of the phone and the battery.
      • Lift the battery with the plastic opening tool and finish removing battery by hand.
      Ask FixBot
    1. GeeksPhone Keon  Antenna Replacement, Back Plate: step 4, image 1 of 2 GeeksPhone Keon  Antenna Replacement, Back Plate: step 4, image 2 of 2
      • Remove the two 5mm T4 screws on the sides of the small orange plate.
      Ask FixBot
    2. GeeksPhone Keon  Antenna Replacement: step 5, image 1 of 2 GeeksPhone Keon  Antenna Replacement: step 5, image 2 of 2
      • Gently remove the small orange plate by pulling it down.
      Ask FixBot
    3. GeeksPhone Keon  Antenna Replacement: step 6, image 1 of 1
      • Remove the following screws securing the back plate to the device:
      • Two silver 2mm T3 screws
      • Five black 3mm T3 screws
      Ask FixBot
    4. GeeksPhone Keon  Antenna Replacement: step 7, image 1 of 3 GeeksPhone Keon  Antenna Replacement: step 7, image 2 of 3 GeeksPhone Keon  Antenna Replacement: step 7, image 3 of 3
      • Slightly lift up the bottom corner of the backplate.
      • Release the four clips on both sides by pulling them away from the device.
      Ask FixBot
    5. GeeksPhone Keon  Antenna Replacement: step 8, image 1 of 2 GeeksPhone Keon  Antenna Replacement: step 8, image 2 of 2
      • Lift the backplate away from the device.
      Ask FixBot
    1. GeeksPhone Keon  Antenna Replacement, Antenna: step 9, image 1 of 1
      • Unfasten the black wire from the metal clamps by hand and lift the black wire away from the device.
      • Unfasten the plastic clamps attached to the antenna.
      Ask FixBot
    2. GeeksPhone Keon  Antenna Replacement: step 10, image 1 of 3 GeeksPhone Keon  Antenna Replacement: step 10, image 2 of 3 GeeksPhone Keon  Antenna Replacement: step 10, image 3 of 3
      • Gently lift the antenna and flip it over to reveal a ZIF connector on the back.
      • Flip up the small retaining flap on the ZIF connector and pull the ribbon cable out.
      Ask FixBot
Author
with
Michael Moran
116 Reputation
1 Guide authored
USF Tampa, Team 3-5, Eyestone Fall 2015 Member of USF Tampa, Team 3-5, Eyestone Fall 2015
USFT-EYESTONE-F15S3G5
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 84
All Time: 708
