Up to 20% off select tools
Gateway W350I Keyboard Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
3
Past 7 Days:
14
Past 30 Days:
91
All Time:
2,229
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This repair is needed in situations where your keyboard stops working. If you have checked that all the keys are properly seated and that there is nothing blocking key movement, replacing the keyboard should correct the issue.
    1. Gateway W350I Keyboard Replacement, Battery Access: step 1, image 1 of 1
      • Turn the laptop upside down and position it as shown in the image.
      Ask FixBot
    2. Gateway W350I Keyboard Replacement, Unlocking the Battery: step 2, image 1 of 3 Gateway W350I Keyboard Replacement, Unlocking the Battery: step 2, image 2 of 3 Gateway W350I Keyboard Replacement, Unlocking the Battery: step 2, image 3 of 3
      • Slide the locking switch towards the open lock picture.
      • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
      • Once the laptop is disengaged, completely remove the battery from the laptop.
      Ask FixBot
    1. Gateway W350I Keyboard Replacement, Unscrewing the Speaker Cover Panel: step 3, image 1 of 1
      • Remove a 4mm Phillips #0 screw just beneath the battery that holds the speaker cover panel.
      Ask FixBot
    2. Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: step 4, image 1 of 2 Gateway W350I Keyboard Replacement, Unscrewing the Keyboard: step 4, image 2 of 2
      • Remove the 4mm Phillips #0 screw that secures the keyboard.
      Ask FixBot
    3. Gateway W350I Keyboard Replacement, Repositioning the Device: step 5, image 1 of 1
      • Reposition the laptop so that it is upright with the display open.
      Ask FixBot
    4. Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: step 6, image 1 of 3 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: step 6, image 2 of 3 Gateway W350I Keyboard Replacement, Removing the Speaker Cover Panel: step 6, image 3 of 3
      • Carefully pry up on the right and left sides of the speaker cover panel.
      • The panel has a cable that connects it to the laptop, so do not pull the panel completely away from the laptop. Instead, disconnect the panel and move it slightly so that it does not interfere with the keyboard.
      Ask FixBot
    5. Gateway W350I Keyboard Replacement, Removing the Keyboard: step 7, image 1 of 2 Gateway W350I Keyboard Replacement, Removing the Keyboard: step 7, image 2 of 2
      • Gently pry up on the corners of the keyboard with the plastic opening tool to free the keyboard.
      Ask FixBot
    6. Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: step 8, image 1 of 2 Gateway W350I Keyboard Replacement, Disconnecting the Keyboard: step 8, image 2 of 2
      • Pull on the cord connecting the keyboard to the computer until it slides out.
      • Be careful while removing the cord as it is very delicate.
      Ask FixBot
3 other people completed this guide.
Author
with
Spencer
278 Reputation
2 Guides authored
USF Tampa, Team 4-1, Brown Fall 2014 Member of USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Members
60 Guides authored
1 Guide Comment
Great guide guys!
stewilli - Reply Share
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 91
All Time: 2,229
