Gateway W350I Heatsink Fan Replacement
    1. Gateway W350I Heatsink Fan Replacement, Battery Access: step 1, image 1 of 1
      • Turn the laptop upside down and position it as shown in the image.
      Ask FixBot
    2. Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: step 2, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: step 2, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Unlocking the Battery: step 2, image 3 of 3
      • Slide the locking switch towards the open lock picture.
      • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
      • Once the laptop is disengaged, completely remove the battery from the laptop.
      Ask FixBot
    1. Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: step 3, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: step 3, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Remove Bottom Cover: step 3, image 3 of 3
      • Remove the single 3mm Phillips #0 screw holding on the plastic cover.
      • Use a plastic opening tool to gently pry off the plastic cover.
      Ask FixBot
    2. Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: step 4, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: step 4, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Remove Srews & Tape: step 4, image 3 of 3
      • Remove all four 3mm Phillips #0 screws holding in the fan.
      • Remove the tape from the top of the fan
      Ask FixBot
    3. Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: step 5, image 1 of 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: step 5, image 2 of 3 Gateway W350I Heatsink Fan Replacement, Removing Heat-Sink Fan: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Gently remove the fan from the metal housing.
      • Disconnect the cable with tweezers.
      Ask FixBot
Aaron Austin
252 Reputation
2 Guides authored
USF Tampa, Team 4-1, Brown Fall 2014 Member of USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 33
All Time: 1,454
