Up to 20% off select tools
Gateway W350I Display Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
91
All Time:
2,066
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This repair will be needed in circumstances where the screen on your laptop stops working properly. If software adjustments do not fix the issue, replacing the display with a new screen should correct the display issue.
    1. Gateway W350I Display Replacement, Battery Access: step 1, image 1 of 1
      • Turn the laptop upside down and position it as shown in the image.
      Ask FixBot
    2. Gateway W350I Display Replacement, Unlocking the Battery: step 2, image 1 of 3 Gateway W350I Display Replacement, Unlocking the Battery: step 2, image 2 of 3 Gateway W350I Display Replacement, Unlocking the Battery: step 2, image 3 of 3
      • Slide the locking switch towards the open lock picture.
      • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
      • Once the laptop is disengaged, completely remove the battery from the laptop.
      Ask FixBot
    1. Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: step 3, image 1 of 2 Gateway W350I Display Replacement, Remove Rubber Protectors & Screws: step 3, image 2 of 2
      • Pry the six black rubber protectors out of the screw holes.
      • Remove all six of the 4mm Phillips #0 screws that were covered by the rubber protectors.
      Ask FixBot
    2. Gateway W350I Display Replacement, Separate Plastic Casing: step 4, image 1 of 2 Gateway W350I Display Replacement, Separate Plastic Casing: step 4, image 2 of 2
      • Separate the plastic screen casing from the laptop lid by inserting a plastic opening tool. Complete this step around the top and along both sides of the screen.
      Ask FixBot
    3. Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: step 5, image 1 of 2 Gateway W350I Display Replacement, Remove Bracket from Laptop Lid: step 5, image 2 of 2
      • Remove the two 4mm Phillips #0 screws located at the top that fasten the screen bracket to the laptop.
      Ask FixBot
    4. Gateway W350I Display Replacement, Remove LCD Screen from Bracket: step 6, image 1 of 1
      • Separate the bracket and the screen from its original position within the lid of the laptop.
      • Remove the four 4mm Phillips #0 screws on the sides of the bracket that hold the LCD screen.
      Ask FixBot
    5. Gateway W350I Display Replacement, Remove Video Cable: step 7, image 1 of 2 Gateway W350I Display Replacement, Remove Video Cable: step 7, image 2 of 2
      • Detach the video cable that is attached to the laptop from the back of the screen.
      • Be careful while removing the video cable as it is very delicate.
      Ask FixBot
    6. Gateway W350I Display Replacement: step 8, image 1 of 2 Gateway W350I Display Replacement: step 8, image 2 of 2
      • Disconnect the camera connector from the circuit board to completely free the screen.
      Ask FixBot
3 other people completed this guide.
Author
with
Samuel Newton
308 Reputation
1 Guide authored
USF Tampa, Team 4-1, Brown Fall 2014 Member of USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Members
60 Guides authored
1 Guide Comment
It was very easy to follow.
Very friendly guide.
stewilli - Reply Share
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 91
All Time: 2,066
