Up to 20% off select tools
Gateway W350I Battery Replacement
Views: 2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
85
All Time:
1,956
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This repair guide is needed if your battery fails to hold a charge and needs to be replaced. The guide should also be followed before working on any electronic component in your laptop. Remember that it is important to remove all power sources before dismantling the laptop.
    1. Gateway W350I Battery Replacement, Battery Access: step 1, image 1 of 1
      • Turn the laptop upside down and position it as shown in the image.
      Ask FixBot
    2. Gateway W350I Battery Replacement, Unlocking the Battery: step 2, image 1 of 3 Gateway W350I Battery Replacement, Unlocking the Battery: step 2, image 2 of 3 Gateway W350I Battery Replacement, Unlocking the Battery: step 2, image 3 of 3
      • Slide the locking switch towards the open lock picture.
      • Hold the release switch in the unlocked position while simultaneously pushing the battery away from the laptop.
      • Once the laptop is disengaged, completely remove the battery from the laptop.
      Ask FixBot
2 other people completed this guide.
Author
with
Spencer
278 Reputation
2 Guides authored
USF Tampa, Team 4-1, Brown Fall 2014 Member of USF Tampa, Team 4-1, Brown Fall 2014
USFT-BROWN-F14S4G1
3 Members
60 Guides authored
1 Guide Comment
This is one of the greatest guides I've ever witnessed!!! It was very simple and user friendly!
stewilli - Reply Share
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 85
All Time: 1,956
