Gateway Solo 1450 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
61
All Time:
774
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide is a replacement guide for the Gateway Solo 1450 Laptop. This guide provides step by step instructions on how to remove and replace the laptop's battery.
    1. Gateway Solo 1450 Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure the device is powered down and disconnected from any power sources. Doing this will eliminate any electrical hazards while working on the device.
      • First it is necessary to locate the battery release button. With the laptop orientated so that the screen hinges are facing up the button is located about halfway up the laptop and slightly to the left.
      Ask FixBot
    2. Gateway Solo 1450 Battery Replacement: step 2, image 1 of 2 Gateway Solo 1450 Battery Replacement: step 2, image 2 of 2
      • The next step is to simultaneously push up on the battery release button and to pull out on the battery itself. If this is not done simultaneously then the battery will not budge.
      Ask FixBot
    3. Gateway Solo 1450 Battery Replacement: step 3, image 1 of 1
      • To fully free the battery it is necessary to firmly grasp the battery and give it a firm tug.
      Ask FixBot
Timothy Post
112 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 61
All Time: 774
