Up to 20% off select tools
Gateway Solo 1200 RAM Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
63
All Time:
1,312
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Follow this replacement guide to replace or upgrade your RAM stick.
Adding memory is one of the easiest ways to boost your Gateway Solo 1200’s performance. To find how much RAM your computer has, go to the device specifications in your PC’s settings. This will not only tell you how much RAM your computer has but also how much RAM it can support for possible upgrades.
    1. Gateway Solo 1200  RAM Replacement, Battery: step 1, image 1 of 3 Gateway Solo 1200  RAM Replacement, Battery: step 1, image 2 of 3 Gateway Solo 1200  RAM Replacement, Battery: step 1, image 3 of 3
      • Turn off your laptop and disconnect it from AC Adapter before use.
      • Locate the battery latch on the bottom of the laptop.
      • Release the latch by pressing it with your thumb and sliding it to the right.
      • Slide the battery out of its compartment.
      • Discharge your laptop by pushing the power button after removing the battery.
      Ask FixBot
    1. Gateway Solo 1200  RAM Replacement, RAM: step 2, image 1 of 1
      • Locate the RAM compartment on the underside of the laptop near the center.
      Ask FixBot
    2. Gateway Solo 1200  RAM Replacement: step 3, image 1 of 2 Gateway Solo 1200  RAM Replacement: step 3, image 2 of 2
      • Open the RAM compartment by unscrewing the 2 mm screw with a Phillips #0 screwdriver.
      • Once unscrewed, lift off the compartment cover.
      Ask FixBot
    3. Gateway Solo 1200  RAM Replacement: step 4, image 1 of 1
      • Press the silver retention levers on either side of the RAM away from the center of the RAM.
      • The RAM stick will pop up after the retention levers are released.
      Ask FixBot
    4. Gateway Solo 1200  RAM Replacement: step 5, image 1 of 1
      • Pull the RAM stick out of its socket.
      Ask FixBot
5 other people completed this guide.
Author
with
Addison
3,165 Reputation
17 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 63
All Time: 1,312
