Up to 20% off select tools
Gateway SA1 RAM Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
89
All Time:
6,404
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Installing upgraded memory.
    1. Gateway SA1 RAM Replacement, Battery: step 1, image 1 of 1
      • Move the latch to the right of the battery to unlock.
      Ask FixBot
    2. Gateway SA1 RAM Replacement: step 2, image 1 of 1
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      Ask FixBot
    1. Gateway SA1 RAM Replacement, RAM: step 3, image 1 of 2 Gateway SA1 RAM Replacement, RAM: step 3, image 2 of 2
      • Loosen the indicated Philips screw that connects the memory bay cover to the casing.
      • The indicated Philips screw does not come out of the cover.
      Ask FixBot
    2. Gateway SA1 RAM Replacement: step 4, image 1 of 2 Gateway SA1 RAM Replacement: step 4, image 2 of 2
      • Lift and remove the cover using the spudger.
      Ask FixBot
    3. Gateway SA1 RAM Replacement: step 5, image 1 of 2 Gateway SA1 RAM Replacement: step 5, image 2 of 2
      • Gently press the clip outwards.
      • The module will tilt up and can be pulled out of the slot.
      • There may be another memory module underneath so be sure to remove both.
      Ask FixBot
    4. Gateway SA1 RAM Replacement: step 6, image 1 of 1
      • To insert a new memory, slide the module into the slot at a 30 to 45 degree angle.
      • Place the first module into the bottom slot then the next module into the top slot.
      • These slots are keyed so verify that you are sliding the module in one direction.
      • Verify that the new memory modules are designed for your specific Gateway Laptop.
      Ask FixBot
3 other people completed this guide.
Author
with
Diego Carteno
273 Reputation
7 Guides authored
Cal Poly, Team 24-20, Regan Spring 2010 Member of Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 89
All Time: 6,404
