Up to 20% off select tools
Gateway SA1 Outer Casing Replacement
Views: 17K
View statistics:
Past 24 Hours:
6
Past 7 Days:
19
Past 30 Days:
97
All Time:
16,830
Comments: 2
2 comments on steps.
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Procedure for dissembling the outer casing of the laptop safely.
    1. Gateway SA1 Outer Casing Replacement, Battery: step 1, image 1 of 1
      • Move the latch to the right of the battery to unlock.
      Ask FixBot
    2. Gateway SA1 Outer Casing Replacement: step 2, image 1 of 1
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      Ask FixBot
    1. Gateway SA1 Outer Casing Replacement, Disk Drive: step 3, image 1 of 1
      • Unscrew the marked 5.9 mm Philips screw.
      Ask FixBot
    2. Gateway SA1 Outer Casing Replacement: step 4, image 1 of 1
      • Use the spudger to pry out the Disk dive.
      Ask FixBot
    3. Gateway SA1 Outer Casing Replacement: step 5, image 1 of 1
      • The disk drive should easily detach and can now be replaced.
      Ask FixBot
    1. Gateway SA1 Outer Casing Replacement, Outer Casing: step 6, image 1 of 1
      • Remove the twelve 5.9 mm Philips screws from the back cover.
      • Remove one 8.8 mm Philips screw from the back cover.
      Ask FixBot
    2. Gateway SA1 Outer Casing Replacement: step 7, image 1 of 3 Gateway SA1 Outer Casing Replacement: step 7, image 2 of 3 Gateway SA1 Outer Casing Replacement: step 7, image 3 of 3
      • Unscrew the two 5.9 mm Philips screws located on the the side closest to the battery.
      • Unscrew the three 3.6 mm Philips screws that are within the Disk drive port.
      Ask FixBot
    3. Gateway SA1 Outer Casing Replacement: step 8, image 1 of 2 Gateway SA1 Outer Casing Replacement: step 8, image 2 of 2
      • Remove the hinge covers by lifting each with the sharp point of the spudger.
      • Notice that the middle cover has a different shape and is more difficult to remove.
      Ask FixBot
    4. Gateway SA1 Outer Casing Replacement: step 9, image 1 of 3 Gateway SA1 Outer Casing Replacement: step 9, image 2 of 3 Gateway SA1 Outer Casing Replacement: step 9, image 3 of 3
      • There will be a connection underneath the speaker cover.
      • Remove the speaker cover using the spudger.
      Ask FixBot
    5. Gateway SA1 Outer Casing Replacement: step 10, image 1 of 1
      • Unscrew the two 3.9 mm Philips screws and remove the keyboard.
      Ask FixBot
    6. Gateway SA1 Outer Casing Replacement: step 11, image 1 of 3 Gateway SA1 Outer Casing Replacement: step 11, image 2 of 3 Gateway SA1 Outer Casing Replacement: step 11, image 3 of 3
      • Carefully lift the keyboard off from the laptop. It is still attached as shown.
      • Using the spudger, detach the connector by pushing two tabs away from the white connector and then gently pulling the connector away.
      • The brown colored component with the tabs does not come out with the connector.
      Ask FixBot
    7. Gateway SA1 Outer Casing Replacement: step 12, image 1 of 3 Gateway SA1 Outer Casing Replacement: step 12, image 2 of 3 Gateway SA1 Outer Casing Replacement: step 12, image 3 of 3
      • Lift up the black tab and gently pull out the connector.
      Ask FixBot
    8. Gateway SA1 Outer Casing Replacement: step 13, image 1 of 2 Gateway SA1 Outer Casing Replacement: step 13, image 2 of 2
      • Unscrew the four marked 5.9 mm Philips screws.
      Ask FixBot
    9. Gateway SA1 Outer Casing Replacement: step 14, image 1 of 2 Gateway SA1 Outer Casing Replacement: step 14, image 2 of 2
      • Move the wires out of the fixed space as shown.
      Ask FixBot
    10. Gateway SA1 Outer Casing Replacement: step 15, image 1 of 2 Gateway SA1 Outer Casing Replacement: step 15, image 2 of 2
      • Unscrew the five marked 3.8 mm Philips screws.
      • Three screws are located on the right side of the screen.
      • Two screws are located on the left side of the screen.
      Ask FixBot
    11. Gateway SA1 Outer Casing Replacement: step 16, image 1 of 1
      • Remove the screen brackets from the computer's base.
      Ask FixBot
    12. Gateway SA1 Outer Casing Replacement: step 17, image 1 of 3 Gateway SA1 Outer Casing Replacement: step 17, image 2 of 3 Gateway SA1 Outer Casing Replacement: step 17, image 3 of 3
      • Remove the four 5.9 mm Philips screws as indicated:
      • There is one somewhat hidden screw on the left side under the screen hinge, and one to the right of the (left)speaker, right/top side of the video port on mobo.
      • There are two similarly positioned screws on the right side.
      Ask FixBot
    13. Gateway SA1 Outer Casing Replacement: step 18, image 1 of 2 Gateway SA1 Outer Casing Replacement: step 18, image 2 of 2
      • The following steps (18 - 20) explain how to remove the three indicated connections.
      • The order is Blue, Violet, Orange.
      • Lift the white tab up and gently take out the connector.
      Ask FixBot
    14. Gateway SA1 Outer Casing Replacement: step 19, image 1 of 1
      • Use the spudger to pull off the black attachment.
      Ask FixBot
    15. Gateway SA1 Outer Casing Replacement: step 20, image 1 of 1
      • Lift and pull the black tab upward until it becomes unattached.
      • Some force may be required.
      Ask FixBot
    16. Gateway SA1 Outer Casing Replacement: step 21, image 1 of 1
      • Use the spudger to remove the casing as seen in the picture.
      Ask FixBot
    17. Gateway SA1 Outer Casing Replacement: step 22, image 1 of 1
      • Remove the casing.
      Ask FixBot
6 other people completed this guide.
Author
with
Diego Carteno
273 Reputation
7 Guides authored
Cal Poly, Team 24-20, Regan Spring 2010 Member of Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 97
All Time: 16,830
