Up to 20% off select tools
Gateway SA1 Disk Drive Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
92
All Time:
4,145
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Parts
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This Guide will help you replace a Gateway Disk Drive.
    1. Gateway SA1 Disk Drive Replacement, Battery: step 1, image 1 of 1
      • Move the latch to the right of the battery to unlock.
      Ask FixBot
    2. Gateway SA1 Disk Drive Replacement: step 2, image 1 of 1
      • Slide the latch on the left directly below the battery to unlock and pull out the battery as shown.
      • The latch must be held in position to remove the battery.
      Ask FixBot
    1. Gateway SA1 Disk Drive Replacement, Disk Drive: step 3, image 1 of 1
      • Unscrew the marked 5.9 mm Philips screw.
      Ask FixBot
    2. Gateway SA1 Disk Drive Replacement: step 4, image 1 of 1
      • Use the spudger to pry out the Disk dive.
      Ask FixBot
    3. Gateway SA1 Disk Drive Replacement: step 5, image 1 of 1
      • The disk drive should easily detach and can now be replaced.
      Ask FixBot
Author
with
Diego Carteno
273 Reputation
7 Guides authored
Cal Poly, Team 24-20, Regan Spring 2010 Member of Cal Poly, Team 24-20, Regan Spring 2010
CPSU-REGAN-S10S24G20
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 92
All Time: 4,145
