Up to 20% off select tools
Gateway P-7805u RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
11
Past 30 Days:
89
All Time:
917
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will teach you how to remove your laptop's RAM. Upgrading RAM is a common practice.
    1. Gateway P-7805u RAM Replacement, RAM: step 1, image 1 of 2 Gateway P-7805u RAM Replacement, RAM: step 1, image 2 of 2
      • Use the J0 screwdriver to remove the five 2mm screws holding the back plate.
      Ask FixBot
    2. Gateway P-7805u RAM Replacement: step 2, image 1 of 1
      • Push the upper RAM module's two pins outwards at the same time.
      • If done correctly, the module should lift.
      Ask FixBot
    3. Gateway P-7805u RAM Replacement: step 3, image 1 of 2 Gateway P-7805u RAM Replacement: step 3, image 2 of 2
      • Grab onto the module and pull away in a straight direction.
      Ask FixBot
    4. Gateway P-7805u RAM Replacement: step 4, image 1 of 2 Gateway P-7805u RAM Replacement: step 4, image 2 of 2
      • Push the lower RAM module's two pins outwards at the same time.
      • If done correctly, the module should have lifted.
      Ask FixBot
Author
with
Emily Pendleton
401 Reputation
4 Guides authored
Baylor, Team S8-G6, Johnson Fall 2017 Member of Baylor, Team S8-G6, Johnson Fall 2017
BU-JOHNSON-F17S8G6
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 89
All Time: 917
