Gateway P-7805u Hard Drive Replacement
View statistics:
Past 24 Hours:
6
Past 7 Days:
21
Past 30 Days:
88
All Time:
656
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will show you how to replace your laptop's hard drive.
    1. Gateway P-7805u Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
      • Unscrew all .5mm screws from the back rectangular panel. Use a J0 screwdriver.
      • Screws will not come out all the way out. Simply unscrew until they do not come out any further.
      Ask FixBot
    2. Gateway P-7805u Hard Drive Replacement: step 2, image 1 of 2 Gateway P-7805u Hard Drive Replacement: step 2, image 2 of 2
      • Firmly press with your hand on the silver surface and pull back, dislodging the hard drive from its port.
      Ask FixBot
    3. Gateway P-7805u Hard Drive Replacement: step 3, image 1 of 1
      • Remove the four 1.2mm screws attaching the case to the hard drive. Use the same J0 screwdriver.
      Ask FixBot
    4. Gateway P-7805u Hard Drive Replacement: step 4, image 1 of 1
      • Pull out the old hard drive.
      Ask FixBot
Emily Pendleton
401 Reputation
4 Guides authored
Baylor, Team S8-G6, Johnson Fall 2017 Member of Baylor, Team S8-G6, Johnson Fall 2017
BU-JOHNSON-F17S8G6
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 21
Past 30 Days: 88
All Time: 656
