Gateway P-6831FX WiFi Card Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
67
All Time:
889
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The WiFi Card is a component that adds wireless connectivity to your device. This guide will go over how to remove and replace the WiFi Card for the P-6831FX.
Tools
    1. Gateway P-6831FX WiFi Card Replacement, WiFi Card: step 1, image 1 of 2 Gateway P-6831FX WiFi Card Replacement, WiFi Card: step 1, image 2 of 2
      • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the WiFi Card.
      • Make sure to unplug your laptop charger, as removing the WiFi while the device is charging may damage the WiFi and or the charger.
      Ask FixBot
    2. Gateway P-6831FX WiFi Card Replacement: step 2, image 1 of 2 Gateway P-6831FX WiFi Card Replacement: step 2, image 2 of 2
      • Gently pull the cover away from the device.
      Ask FixBot
    3. Gateway P-6831FX WiFi Card Replacement: step 3, image 1 of 3 Gateway P-6831FX WiFi Card Replacement: step 3, image 2 of 3 Gateway P-6831FX WiFi Card Replacement: step 3, image 3 of 3
      • Remove the three wires above the WiFi Card.
      • Take note of the color for each wire and it's corresponding location.
      Ask FixBot
    4. Gateway P-6831FX WiFi Card Replacement: step 4, image 1 of 3 Gateway P-6831FX WiFi Card Replacement: step 4, image 2 of 3 Gateway P-6831FX WiFi Card Replacement: step 4, image 3 of 3
      • Remove the two Phillips #0 (2mm) screws above the WiFi card.
      • The WiFi Card will lift up once the screws are removed.
      Ask FixBot
    5. Gateway P-6831FX WiFi Card Replacement: step 5, image 1 of 2 Gateway P-6831FX WiFi Card Replacement: step 5, image 2 of 2
      • With the WiFi Card lifted up, gently pull the WiFi Card out of the socket and remove it from the device.
      Ask FixBot
Chandler Jardin
507 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 67
All Time: 889
