Up to 20% off select tools
Gateway P-6831FX RAM Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
53
All Time:
716
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The RAM is a component that will act as a quick storage for your device. This guide will go over how to remove and replace the RAM for the P-6831FX.
    1. Gateway P-6831FX RAM Replacement, RAM: step 1, image 1 of 2 Gateway P-6831FX RAM Replacement, RAM: step 1, image 2 of 2
      • Turn your laptop upside down and remove the five Philips #0 (5mm) screws for the cover of the RAM.
      • Make sure to unplug your laptop charger, as removing the RAM while the device is charging may damage the RAM and or the charger.
      Ask FixBot
    2. Gateway P-6831FX RAM Replacement: step 2, image 1 of 2 Gateway P-6831FX RAM Replacement: step 2, image 2 of 2
      • Gently pull the cover away from the device.
      • Set the cover aside for now, until reassembly.
      Ask FixBot
    3. Gateway P-6831FX RAM Replacement: step 3, image 1 of 3 Gateway P-6831FX RAM Replacement: step 3, image 2 of 3 Gateway P-6831FX RAM Replacement: step 3, image 3 of 3
      • Pull the metal tabs and lift the first RAM stick out of the socket.
      Ask FixBot
    4. Gateway P-6831FX RAM Replacement: step 4, image 1 of 3 Gateway P-6831FX RAM Replacement: step 4, image 2 of 3 Gateway P-6831FX RAM Replacement: step 4, image 3 of 3
      • Repeat Step 3 to remove the second RAM stick.
      Ask FixBot
Author
with
Chandler Jardin
507 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 53
All Time: 716
