Gateway P-6831FX Hard Drive Replacement
    1. Gateway P-6831FX Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 Gateway P-6831FX Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
      • Turn your laptop upside down and remove the four Philips #0 (5mm) screws for the cover of the hard drive.
      • Make sure to unplug your laptop charger, as removing the hard drive while the device is charging may damage the hard drive and or the charger.
      Ask FixBot
    2. Gateway P-6831FX Hard Drive Replacement: step 2, image 1 of 2 Gateway P-6831FX Hard Drive Replacement: step 2, image 2 of 2
      • Gently pull the cover away from the device.
      • Set the cover aside for now, until reassembly.
      Ask FixBot
    3. Gateway P-6831FX Hard Drive Replacement: step 3, image 1 of 2 Gateway P-6831FX Hard Drive Replacement: step 3, image 2 of 2
      • Pull the plastic tab as shown to remove the hard drive from the device.
      Ask FixBot
    4. Gateway P-6831FX Hard Drive Replacement: step 4, image 1 of 2 Gateway P-6831FX Hard Drive Replacement: step 4, image 2 of 2
      • Remove the four Philips #0 (3mm) screws around the case for the hard drive. There will be two screws and the left and right side.
      Ask FixBot
    5. Gateway P-6831FX Hard Drive Replacement: step 5, image 1 of 3 Gateway P-6831FX Hard Drive Replacement: step 5, image 2 of 3 Gateway P-6831FX Hard Drive Replacement: step 5, image 3 of 3
      • Remove the hard drive from the case.
      Ask FixBot
Chandler Jardin
507 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 67
All Time: 761
