Gateway NV59C66u Battery Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
15
Past 30 Days:
66
All Time:
643
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Does your computer die sooner than it did when you bought it? You may need to replace your battery as it might be damaged. This step-by-step guide will show you how to quickly and safely replace your battery for your Gateway NV59C66u laptop.
    1. Gateway NV59C66u Battery Replacement, Battery: step 1, image 1 of 1
      • First turn off your laptop, close it, then turn your laptop over exposing the bottom side.
      • Locate the Latches below the battery.
      Ask FixBot
    2. Gateway NV59C66u Battery Replacement: step 2, image 1 of 1
      • Slide the vertical latch upward, unlocking the battery
      Ask FixBot
    3. Gateway NV59C66u Battery Replacement: step 3, image 1 of 1
      • Slide the horizontal latch to the right so you are able to remove the battery from the bottom of your laptop.
      Ask FixBot
    4. Gateway NV59C66u Battery Replacement: step 4, image 1 of 1
      • Now the battery is free. Proceed to lift and remove the battery.
      Ask FixBot
      • Place the old batter to the side, as to not get it confused from your new battery you intend to install.
      Ask FixBot
      • Take your new battery and position it into the battery slot you took the old one out of.
      Ask FixBot
      • Make sure latches are in the unlocked position and apply light pressure on the new battery to make sure it is in place.
      Ask FixBot
      • Put latches in lock position and turn laptop over.
      Ask FixBot
      • Turn on your computer.
      Ask FixBot
Jackson Gandee
521 Reputation
4 Guides authored
ETECH Holdings Member of ETECH Holdings
Community
2 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 66
All Time: 643
