Up to 20% off select tools
Gateway NV55C49u RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
56
All Time:
800
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your laptop is running slowly, or crashing unexpectedly, the issue could be with faulty or insufficient RAM. Use this guide to upgrade or replace the laptop’s RAM. The RAM replacement is fairly simple on this laptop because it doesn’t require a full disassembly.
    1. Gateway NV55C49u RAM Replacement, RAM: step 1, image 1 of 1
      • Flip the laptop bottom side up.
      Ask FixBot
    2. Gateway NV55C49u RAM Replacement: step 2, image 1 of 1
      • Slide the battery lock to show the red background.
      Ask FixBot
    3. Gateway NV55C49u RAM Replacement: step 3, image 1 of 2 Gateway NV55C49u RAM Replacement: step 3, image 2 of 2
      • Push the battery slider to the other side. This will automatically eject the battery.
      • You can now remove the battery.
      Ask FixBot
    4. Gateway NV55C49u RAM Replacement: step 4, image 1 of 1
      • Remove the two 6.0mm Phillips #00 screws from the back cover.
      Ask FixBot
    5. Gateway NV55C49u RAM Replacement: step 5, image 1 of 3 Gateway NV55C49u RAM Replacement: step 5, image 2 of 3 Gateway NV55C49u RAM Replacement: step 5, image 3 of 3
      • Remove the back cover by placing the plastic opening tool in the indention, and prying upwards.
      Ask FixBot
    6. Gateway NV55C49u RAM Replacement: step 6, image 1 of 2 Gateway NV55C49u RAM Replacement: step 6, image 2 of 2
      • Hold back the plastic that protects the RAM so you can access the clips underneath.
      • Gently push the holding clips outwards. The RAM will angle itself upwards.
      • Gently remove the RAM from the laptop
      • Make sure not to touch any part of the RAM except the sides.
      • When reassembling, insert the RAM into the connector, and then push it down until the clips lock it into place
      Ask FixBot
2 other people completed this guide.
Author
with
Matthew
409 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 56
All Time: 800
