Gateway NV55C49u Display Replacement
    1. Gateway NV55C49u Display Replacement, Display: step 1, image 1 of 1
      • Flip the laptop bottom side up.
      Ask FixBot
    2. Gateway NV55C49u Display Replacement: step 2, image 1 of 1
      • Slide the battery lock to show the red background.
      Ask FixBot
    3. Gateway NV55C49u Display Replacement: step 3, image 1 of 2 Gateway NV55C49u Display Replacement: step 3, image 2 of 2
      • Push the battery slider to the other side. This will automatically eject the battery.
      • You can now remove the battery
      Ask FixBot
    4. Gateway NV55C49u Display Replacement: step 4, image 1 of 1
      • Remove the two 6.0mm Phillips #00 screws from the back cover.
      Ask FixBot
    5. Gateway NV55C49u Display Replacement: step 5, image 1 of 2 Gateway NV55C49u Display Replacement: step 5, image 2 of 2
      • Remove the back cover by placing a plastic opening tool in the indention and prying upwards.
      Ask FixBot
    6. Gateway NV55C49u Display Replacement: step 6, image 1 of 1
      • Remove the four 3.0mm Phillips #0 screws from the battery compartment.
      Ask FixBot
    7. Gateway NV55C49u Display Replacement: step 7, image 1 of 1
      • Remove the two 6.0mm #00 Phillips screws from the area under the back cover.
      Ask FixBot
    8. Gateway NV55C49u Display Replacement: step 8, image 1 of 1
      • Remove the nine 6.0mm #00 Phillips screws from the back of the laptop.
      Ask FixBot
    9. Gateway NV55C49u Display Replacement: step 9, image 1 of 3 Gateway NV55C49u Display Replacement: step 9, image 2 of 3 Gateway NV55C49u Display Replacement: step 9, image 3 of 3
      • There are 6 small clips that holding the top row of the keyboard in place.
      • To remove the keyboard, push each of these clips in with a metal spudger while simultaneously using a plastic opening tool to pry the keyboard up.
      • Once the top row is loose you can use the plastic opening tool to gently pry the rest of the keyboard off the laptop.
      Ask FixBot
    10. Gateway NV55C49u Display Replacement: step 10, image 1 of 1
      • Once the keyboard is loose, slowly lift the keyboard away from the laptop.
      • There will be a single ribbon cable connecting the keyboard to the laptop body. Use two plastic opening tools to loosen the fastener,
      • After the fastener is loose, gently disconnect the cable.
      • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much pressure.
      Ask FixBot
    11. Gateway NV55C49u Display Replacement: step 11, image 1 of 3 Gateway NV55C49u Display Replacement: step 11, image 2 of 3 Gateway NV55C49u Display Replacement: step 11, image 3 of 3
      • Remove the 3 ribbon cables using a plastic pry tool to gently push the fasteners loose and gently pulling the cables out.
      • Ribbon cables should come out easily once the fasteners are loose. Do not apply too much force.
      • Use a plastic pry tool to disconnect the single pinned connector.
      Ask FixBot
    12. Gateway NV55C49u Display Replacement: step 12, image 1 of 1
      • Use a plastic opening tool to remove the disk drive cover on the right side of the laptop.
      Ask FixBot
    13. Gateway NV55C49u Display Replacement: step 13, image 1 of 2 Gateway NV55C49u Display Replacement: step 13, image 2 of 2
      • Use the metal spudger to pry upwards on the disk drive until you can grab and remove it.
      Ask FixBot
    14. Gateway NV55C49u Display Replacement: step 14, image 1 of 1
      • Now simply lift the face-plate off the laptop body.
      • This step exposes the motherboard, which is a sensitive part of the laptop. Make sure not to touch anything with your bare hands as a static shock could ruin the board.
      Ask FixBot
    15. Gateway NV55C49u Display Replacement: step 15, image 1 of 1
      • Remove the ribbon wire that connects the display to the motherboard using two plastic opening tools.
      Ask FixBot
    16. Gateway NV55C49u Display Replacement: step 16, image 1 of 2 Gateway NV55C49u Display Replacement: step 16, image 2 of 2
      • Remove the two 4.0mm #00 Phillips screws from both the top right and top left of the exposed laptop body.
      • The display is now fully disconnected.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 70
All Time: 836
