Gateway NV55C49u Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
66
All Time:
802
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your laptop charge is draining quickly, or the laptop won’t turn on, use this guide to replace the battery. The battery replacement on this laptop is a simple swap because there are no screws, glue, or small parts you have to work with.
Tools
    1. Gateway NV55C49u Battery Replacement, Battery: step 1, image 1 of 1
      • Flip the laptop bottom side up.
      Ask FixBot
    2. Gateway NV55C49u Battery Replacement: step 2, image 1 of 1
      • Switch the battery lock to show a red background with an unlock symbol
      Ask FixBot
    3. Gateway NV55C49u Battery Replacement: step 3, image 1 of 2 Gateway NV55C49u Battery Replacement: step 3, image 2 of 2
      • Flip the switch with the battery symbol on it.
      • The battery should eject if done correctly.
      Ask FixBot
    4. Gateway NV55C49u Battery Replacement: step 4, image 1 of 1
      • Remove the battery by lifting the battery out.
      Ask FixBot
    5. Gateway NV55C49u Battery Replacement: step 5, image 1 of 1
      • This battery contains harmful chemicals, so it must be disposed of properly. Please take the old battery to a waste disposal center or recycling center.
      • Tip: in France, you can dispose of the old battery in the battery disposal points that can be found in a lot of supermarkets.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 66
All Time: 802
