Gateway NV53A24u Fan Replacement
    1. Gateway NV53A24u Fan Replacement, Fan: step 1, image 1 of 2 Gateway NV53A24u Fan Replacement, Fan: step 1, image 2 of 2
      • Locate the top of the keyboard, then insert a spudger into the top most edge of the keyboard where it meets the bezel surrounding it.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but a regular black nylon spudger should be used whenever possible.
      Ask FixBot
    2. Gateway NV53A24u Fan Replacement: step 2, image 1 of 1
      • Using the spudger, lift the keyboard from its base to expose the underside components.
      Ask FixBot
    3. Gateway NV53A24u Fan Replacement: step 3, image 1 of 2 Gateway NV53A24u Fan Replacement: step 3, image 2 of 2
      • Using a #4 phillips screwdriver, remove all six 2.3mm screws from the plastic shroud.
      • Then, lift off the shroud to reveal the motherboard beneath.
      Ask FixBot
    4. Gateway NV53A24u Fan Replacement: step 4, image 1 of 2 Gateway NV53A24u Fan Replacement: step 4, image 2 of 2
      • The motherboard is now readily accessible to be removed.
      • Using a spudger, gently pry the ports away from their side port containers to easily remove it.
      Ask FixBot
    5. Gateway NV53A24u Fan Replacement: step 5, image 1 of 2 Gateway NV53A24u Fan Replacement: step 5, image 2 of 2
      • Lift the motherboard up and flip it on its back.
      • With the motherboard flipped, the fan is almost ready to be removed.
      Ask FixBot
    6. Gateway NV53A24u Fan Replacement: step 6, image 1 of 2 Gateway NV53A24u Fan Replacement: step 6, image 2 of 2
      • Locate the fan and its copper heat pipe running just behind it.
      • Remove the fan from the heat pipe using slight force as it is held to the pipe with an adhesive tape.
      Ask FixBot
Minh Harper
156 Reputation
1 Guide authored
USF Tampa, Team 1-5, Leahy Fall 2016 Member of USF Tampa, Team 1-5, Leahy Fall 2016
USFT-LEAHY-F16S1G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 96
All Time: 1,139
