Up to 20% off select tools
Gateway NV52 WiFi Card Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
90
All Time:
1,914
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
Introduction
Go to step 1 ↓
The only prerequisite for the WiFi card is the Base Cover.
    1. Gateway NV52 WiFi Card Replacement, Base Cover: step 1, image 1 of 1
      • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
      Ask FixBot
    2. Gateway NV52 WiFi Card Replacement: step 2, image 1 of 1
      • Lift up the base cover from the the top with your hands to a 90 degree angle.
      • Remove the base cover and place it in a safe and dry place.
      Ask FixBot
    1. Gateway NV52 WiFi Card Replacement, WiFi Card: step 3, image 1 of 1
      • Remove the 3/16" screw located at the bottom left corner of the WiFi card using a Phillips #0 Screwdriver.
      Ask FixBot
    2. Gateway NV52 WiFi Card Replacement: step 4, image 1 of 1
      • Locate the black and white cables attached to the WiFi card.
      • Gently wiggle the black cable until it detaches from the WiFi card.
      • Repeat the previous step for the white cable.
      Ask FixBot
    3. Gateway NV52 WiFi Card Replacement: step 5, image 1 of 1
      • Gently, remove the Wifi card from its slot, and place it in a dry and safe place.
      Ask FixBot
Author
with
Ruben
298 Reputation
2 Guides authored
Cal Poly, Team 7-24, Regan Spring 2014 Member of Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 90
All Time: 1,914
