Gateway NV52 Hard Drive Compartment Replacement
    1. Gateway NV52 Hard Drive Compartment Replacement, Base Cover: step 1, image 1 of 1
      • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
      Ask FixBot
    2. Gateway NV52 Hard Drive Compartment Replacement: step 2, image 1 of 1
      • Lift up the base cover from the the top with your hands to a 90 degree angle.
      • Remove the base cover and place it in a safe and dry place.
      Ask FixBot
    1. Gateway NV52 Hard Drive Compartment Replacement, Hard Drive Compartment: step 3, image 1 of 1
      • Remove the 1/4" Phillip screw located at the top right of the Hard Drive using a Phillips #0 Screwdriver .
      Ask FixBot
    2. Gateway NV52 Hard Drive Compartment Replacement: step 4, image 1 of 3 Gateway NV52 Hard Drive Compartment Replacement: step 4, image 2 of 3 Gateway NV52 Hard Drive Compartment Replacement: step 4, image 3 of 3
      • Remove the Hard Drive component from its compartment. To do so, slide the component downward away from the battery pack.
      • Lift the Hard Drive to a 90 degree angle and out of its slot.
      • Place the Hard Drive in a designated zone.
      Ask FixBot
2 other people completed this guide.
Tim En
557 Reputation
4 Guides authored
Cal Poly, Team 7-24, Regan Spring 2014 Member of Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 23
Past 30 Days: 110
All Time: 1,553
