Up to 20% off select tools
Gateway NV52 Base Cover Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
75
All Time:
1,638
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Tools
Introduction
Go to step 1 ↓
This guide will be a prerequisite for other laptop's components.
    1. Gateway NV52 Base Cover Replacement, Base Cover: step 1, image 1 of 1
      • Remove the five identical 3/16" Phillips screws that secures the hard drive and memory cover using a Phillips #0 Screwdriver.
      Ask FixBot
    2. Gateway NV52 Base Cover Replacement: step 2, image 1 of 1
      • Lift up the base cover from the the top with your hands to a 90 degree angle.
      • Remove the base cover and place it in a safe and dry place.
      Ask FixBot
Author
with
Irma Marin
608 Reputation
3 Guides authored
Cal Poly, Team 7-24, Regan Spring 2014 Member of Cal Poly, Team 7-24, Regan Spring 2014
CPSU-REGAN-S14S7G24
4 Members
108 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 75
All Time: 1,638
