Gateway NE52214U Fan Replacement
    1. Gateway NE52214U Fan Replacement, Battery: step 1, image 1 of 1
      • Make sure to power down and turn off the laptop before proceeding with this guide.
      • Flip over the laptop.
      Ask FixBot
    2. Gateway NE52214U Fan Replacement: step 2, image 1 of 2 Gateway NE52214U Fan Replacement: step 2, image 2 of 2
      • Slide the tab to the left and hold the tab there.
      • While holding down the sliding tab, remove the battery from the device.
      Ask FixBot
    1. Gateway NE52214U Fan Replacement, Upper Case: step 3, image 1 of 2 Gateway NE52214U Fan Replacement, Upper Case: step 3, image 2 of 2
      • After removing the battery, remove 15 7mm screws using the Phillip #1 Screwdriver.
      Ask FixBot
    2. Gateway NE52214U Fan Replacement: step 4, image 1 of 1
      • Flip over the laptop and open it so the screen is facing you.
      Ask FixBot
    3. Gateway NE52214U Fan Replacement: step 5, image 1 of 1
      • Lift the upper case cover off of the device. Use a prying tool along the edges if necessary.
      Ask FixBot
    1. Gateway NE52214U Fan Replacement, Motherboard: step 6, image 1 of 1
      • Remove the twelve 3mm screws using the Phillips #00 screwdriver.
      Ask FixBot
    2. Gateway NE52214U Fan Replacement: step 7, image 1 of 2 Gateway NE52214U Fan Replacement: step 7, image 2 of 2
      • Gently lift and remove the motherboard off of device.
      • This will also remove the fan from the device but it will remain attached to the motherboard.
      Ask FixBot
    1. Gateway NE52214U Fan Replacement, Fan: step 8, image 1 of 1
      • Remove the four 3mm screws attaching the fan to motherboard using the Phillips #00 screwdriver.
      Ask FixBot
    2. Gateway NE52214U Fan Replacement: step 9, image 1 of 2 Gateway NE52214U Fan Replacement: step 9, image 2 of 2
      • Gently lift the fan and disconnect the fan from the motherboard.
      • Remove the fan from the device.
      Ask FixBot
Kelsey Rodrigues
495 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 14
Past 30 Days: 47
All Time: 525
