Up to 20% off select tools
Gateway NE52203u Wireless Card Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
86
All Time:
1,193
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If you can't connect to a wireless internet signal, a faulty wireless card is most likely the problem and you’ll have to replace it with a functioning one. This guide will provide you with the steps necessary to replace your old wireless card with a new one, so you can get back to surfing the web!
    1. Gateway NE52203u Wireless Card Replacement, Battery: step 1, image 1 of 1
      • Flip the device over onto its backside in order to access the battery.
      Ask FixBot
    2. Gateway NE52203u Wireless Card Replacement: step 2, image 1 of 2 Gateway NE52203u Wireless Card Replacement: step 2, image 2 of 2
      • Locate the battery release latch and slide it over to the other side.
      • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
      Ask FixBot
    3. Gateway NE52203u Wireless Card Replacement: step 3, image 1 of 1
      • Grab the newly ejected battery from the device to completely remove it.
      • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
      Ask FixBot
    1. Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: step 4, image 1 of 2 Gateway NE52203u Wireless Card Replacement, Touchpad Assembly: step 4, image 2 of 2
      • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
      • Remove 5 6.0 mm Phillip #00 screws from under cover.
      Ask FixBot
    2. Gateway NE52203u Wireless Card Replacement: step 5, image 1 of 1
      • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
      Ask FixBot
    3. Gateway NE52203u Wireless Card Replacement: step 6, image 1 of 2 Gateway NE52203u Wireless Card Replacement: step 6, image 2 of 2
      • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
      Ask FixBot
    4. Gateway NE52203u Wireless Card Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
      Ask FixBot
    5. Gateway NE52203u Wireless Card Replacement: step 8, image 1 of 3 Gateway NE52203u Wireless Card Replacement: step 8, image 2 of 3 Gateway NE52203u Wireless Card Replacement: step 8, image 3 of 3
      • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
      • First flip open the flap covering the ribbon using a spudger or fingernail.
      • Second gently pull the ribbon away from the port.
      Ask FixBot
    1. Gateway NE52203u Wireless Card Replacement, Wireless Card: step 9, image 1 of 2 Gateway NE52203u Wireless Card Replacement, Wireless Card: step 9, image 2 of 2
      Buy
      • Grab the antenna cable with tweezers and lift up to pull it off.
      • The antenna is the small black cable with the golden head
      Ask FixBot
    2. Gateway NE52203u Wireless Card Replacement: step 10, image 1 of 1
      • Remove the one 2.9 mm Phillips #00 screw holding down the wireless card in place.
      Ask FixBot
    3. Gateway NE52203u Wireless Card Replacement: step 11, image 1 of 1
      • After the screw is removed, the card will spring upwards slightly. Pull out the old wireless card from its port.
      Ask FixBot
Author
with
Stephen Spees
542 Reputation
4 Guides authored
Baylor, Team 2-1, Grigsby Spring 2015 Member of Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 86
All Time: 1,193
