Gateway NE52203u USB Port Replacement
    1. Gateway NE52203u USB Port Replacement, Battery: step 1, image 1 of 1
      • Flip the device over onto its backside in order to access the battery.
      Ask FixBot
    2. Gateway NE52203u USB Port Replacement: step 2, image 1 of 2 Gateway NE52203u USB Port Replacement: step 2, image 2 of 2
      • Locate the battery release latch and slide it over to the other side.
      • A small tool like a pen or screwdriver may be helpful in sliding the latch to release the battery.
      Ask FixBot
    3. Gateway NE52203u USB Port Replacement: step 3, image 1 of 1
      • Grab the newly ejected battery from the device to completely remove it.
      • When reinserting the new battery, make sure the prongs on the battery are aligned with the corresponding holes on the laptop.
      Ask FixBot
    1. Gateway NE52203u USB Port Replacement, Touchpad Assembly: step 4, image 1 of 2 Gateway NE52203u USB Port Replacement, Touchpad Assembly: step 4, image 2 of 2
      • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
      • Remove 5 6.0 mm Phillip #00 screws from under cover.
      Ask FixBot
    2. Gateway NE52203u USB Port Replacement: step 5, image 1 of 1
      • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
      Ask FixBot
    3. Gateway NE52203u USB Port Replacement: step 6, image 1 of 2 Gateway NE52203u USB Port Replacement: step 6, image 2 of 2
      • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
      Ask FixBot
    4. Gateway NE52203u USB Port Replacement: step 7, image 1 of 1
      Tool used on this step:
      Buy
      • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
      Ask FixBot
    5. Gateway NE52203u USB Port Replacement: step 8, image 1 of 3 Gateway NE52203u USB Port Replacement: step 8, image 2 of 3 Gateway NE52203u USB Port Replacement: step 8, image 3 of 3
      • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
      • First flip open the flap covering the ribbon using a spudger or fingernail.
      • Second gently pull the ribbon away from the port.
      Ask FixBot
    1. Gateway NE52203u USB Port Replacement, USB Port: step 9, image 1 of 2 Gateway NE52203u USB Port Replacement, USB Port: step 9, image 2 of 2
      • Using a spudger, pry the ZIF connector upwards.
      Ask FixBot
    2. Gateway NE52203u USB Port Replacement: step 10, image 1 of 1
      • Use your fingers to gently disconnect the ribbon wire from the USB circuit board.
      Ask FixBot
    3. Gateway NE52203u USB Port Replacement: step 11, image 1 of 1
      • Using a #00 Phillips head screwdriver, remove the 2.9 mm screw on the USB circuit board.
      Ask FixBot
    4. Gateway NE52203u USB Port Replacement: step 12, image 1 of 1
      • Finally, remove the old USB port.
      Ask FixBot
3 other people completed this guide.
Stephen Spees
542 Reputation
4 Guides authored
Baylor, Team 2-1, Grigsby Spring 2015 Member of Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 91
All Time: 1,081
