Gateway NE52203u Touchpad Assembly Replacement
    1. Gateway NE52203u Touchpad Assembly Replacement, Touchpad Assembly: step 1, image 1 of 2 Gateway NE52203u Touchpad Assembly Replacement, Touchpad Assembly: step 1, image 2 of 2
      • Remove 18 6.0 mm Phillips #00 screws from the bottom of the laptop.
      • Remove 5 6.0 mm Phillip #00 screws from under cover.
      Ask FixBot
    2. Gateway NE52203u Touchpad Assembly Replacement: step 2, image 1 of 1
      • Remove three 2.9 mm Phillips #00 screws from the battery compartment.
      Ask FixBot
    3. Gateway NE52203u Touchpad Assembly Replacement: step 3, image 1 of 2 Gateway NE52203u Touchpad Assembly Replacement: step 3, image 2 of 2
      • Separate the bottom panel from the touchpad assembly by inserting a plastic opening tool between them on all four sides.
      Ask FixBot
    4. Gateway NE52203u Touchpad Assembly Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Pull black ribbon wire from port using tweezers in order to completely separate touchpad assembly from bottom assembly.
      Ask FixBot
    5. Gateway NE52203u Touchpad Assembly Replacement: step 5, image 1 of 3 Gateway NE52203u Touchpad Assembly Replacement: step 5, image 2 of 3 Gateway NE52203u Touchpad Assembly Replacement: step 5, image 3 of 3
      • Disconnect the two ZIF ports that attach the touchpad assembly to the motherboard.
      • First flip open the flap covering the ribbon using a spudger or fingernail.
      • Second gently pull the ribbon away from the port.
      Ask FixBot
Stephen Spees
542 Reputation
4 Guides authored
Baylor, Team 2-1, Grigsby Spring 2015 Member of Baylor, Team 2-1, Grigsby Spring 2015
BU-GRIGSBY-S15S2G1
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 105
All Time: 1,278
