Up to 20% off select tools
Gateway MS2370 RAM Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
88
All Time:
2,347
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
  • 64 Bit Driver Kit
    $33.96 $39.95
    4.9
Introduction
Go to step 1 ↓
This guide shows the user how to properly remove the RAM from the Gateway MS2370 Laptop.
    1. Gateway MS2370 RAM Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
      Ask FixBot
    2. Gateway MS2370 RAM Replacement: step 2, image 1 of 1
      • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
      Ask FixBot
    3. Gateway MS2370 RAM Replacement: step 3, image 1 of 1
      • Pull the battery from the laptop to remove it.
      Ask FixBot
    1. Gateway MS2370 RAM Replacement, RAM: step 4, image 1 of 1
      • Unscrew the three 10mm inch Phillips 01 screws on the back of your laptop.
      • Unplug everything from the USB and SD ports.
      Ask FixBot
    2. Gateway MS2370 RAM Replacement: step 5, image 1 of 1
      • Remove the cover panel.
      • This exposes more screws that must be removed.
      Ask FixBot
    3. Gateway MS2370 RAM Replacement: step 6, image 1 of 1
      • Unplug the two exposed cables from the motherboard.
      Ask FixBot
    4. Gateway MS2370 RAM Replacement: step 7, image 1 of 2 Gateway MS2370 RAM Replacement: step 7, image 2 of 2
      • Unscrew the rest of the case screws which include several 10mm 01 Phillips screws and three 3mm 00 Phillips screws.
      • This marked screw will not fully come out. Just loosen it and leave it there it will not effect the rest of the replacement.
      Ask FixBot
    5. Gateway MS2370 RAM Replacement: step 8, image 1 of 2 Gateway MS2370 RAM Replacement: step 8, image 2 of 2
      • Pry the laptop case apart.
      • The disc drive in this photo was removed. You can remove it just by puling it out when the previous step is completed.
      Ask FixBot
    6. Gateway MS2370 RAM Replacement: step 9, image 1 of 1
      • Unplug the track-pad and the keyboard ribbon cable by lifting up the grey flap and removing the cable.
      • This cable has a special connector the requires you to lift open a grey flap to unplug properly.
      • The keyboard plug is located at the center of the motherboard and can be unplugged like a normal cable.
      Ask FixBot
    7. Gateway MS2370 RAM Replacement: step 10, image 1 of 1
      • Remove the top half of the case.
      Ask FixBot
    8. Gateway MS2370 RAM Replacement: step 11, image 1 of 1
      • Unscrew all 5 10mm inch Phillips 01 screws.
      • One more off screen
      Ask FixBot
    9. Gateway MS2370 RAM Replacement: step 12, image 1 of 3 Gateway MS2370 RAM Replacement: step 12, image 2 of 3 Gateway MS2370 RAM Replacement: step 12, image 3 of 3
      • Unplug the ribbon cable connected to the USB Hub, the network card, and the monitor cable.
      Ask FixBot
    10. Gateway MS2370 RAM Replacement: step 13, image 1 of 1
      • Flip the motherboard over.
      Ask FixBot
    11. Gateway MS2370 RAM Replacement: step 14, image 1 of 3 Gateway MS2370 RAM Replacement: step 14, image 2 of 3 Gateway MS2370 RAM Replacement: step 14, image 3 of 3
      • Using your two thumbs to pull outwards from the inside of the RAM slot to release and remove the RAM.
      • The last step of this replacement guide is not required to complete the fan replacement guide.
      Ask FixBot
2 other people completed this guide.
Author
with
Mathieu Bolduc-Clayton
518 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 88
All Time: 2,347
