Up to 20% off select tools
Gateway MS2370 Keyboard Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
82
All Time:
1,538
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide shows the user how to properly remove the keyboard from the Gateway MS2370 Laptop.
    1. Gateway MS2370 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
      Ask FixBot
    2. Gateway MS2370 Keyboard Replacement: step 2, image 1 of 1
      • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
      Ask FixBot
    3. Gateway MS2370 Keyboard Replacement: step 3, image 1 of 1
      • Pull the battery from the laptop to remove it.
      Ask FixBot
    1. Gateway MS2370 Keyboard Replacement, Keyboard: step 4, image 1 of 1
      • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
      Ask FixBot
    2. Gateway MS2370 Keyboard Replacement: step 5, image 1 of 1
      • Carefully lift the keyboard molding out.
      Ask FixBot
    3. Gateway MS2370 Keyboard Replacement: step 6, image 1 of 1
      • Use the plastic spudger again to pry the keyboard tabs from the laptop.
      Ask FixBot
    4. Gateway MS2370 Keyboard Replacement: step 7, image 1 of 1
      • Slowly lift the keyboard from the laptop.
      Ask FixBot
    5. Gateway MS2370 Keyboard Replacement: step 8, image 1 of 2 Gateway MS2370 Keyboard Replacement: step 8, image 2 of 2
      • Carefully unplug the ribbon cable attached to the motherboard.
      • The ribbon cable is extremely delicate, handle with care
      Ask FixBot
    6. Gateway MS2370 Keyboard Replacement: step 9, image 1 of 1
      • Lift and remove the keyboard from the computer.
      Ask FixBot
Author
with
Mathieu Bolduc-Clayton
518 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 82
All Time: 1,538
