Up to 20% off select tools
Gateway MS2285 RAM Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
90
All Time:
3,238
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will teach you how to remove your RAM modules. Upgrading RAM is a common practice among users. One thing to note is that if you want to only remove the lower RAM module, you have to remove the top one first.
    1. Gateway MS2285 RAM Replacement, Turn Laptop Over: step 1, image 1 of 1
      • Turn the laptop over so that the underside is facing towards you.
      Ask FixBot
    2. Gateway MS2285 RAM Replacement, Unlock The Battery: step 2, image 1 of 2 Gateway MS2285 RAM Replacement, Unlock The Battery: step 2, image 2 of 2
      • Slide the short slider one towards the unlocked lock symbol.
      Ask FixBot
    3. Gateway MS2285 RAM Replacement, Release The Battery: step 3, image 1 of 2 Gateway MS2285 RAM Replacement, Release The Battery: step 3, image 2 of 2
      • Slide the long slider towards the unlocked lock icon.
      • This slider is spring loaded and may require a little force.
      • If done correctly, a click will be heard and the battery will be slightly raised.
      Ask FixBot
    4. Gateway MS2285 RAM Replacement, Remove The Battery: step 4, image 1 of 2 Gateway MS2285 RAM Replacement, Remove The Battery: step 4, image 2 of 2
      • Grasp the battery's raised end and lift upwards.
      Ask FixBot
    1. Gateway MS2285 RAM Replacement, Unscrew Backplate: step 5, image 1 of 2 Gateway MS2285 RAM Replacement, Unscrew Backplate: step 5, image 2 of 2
      • Use the phillips head screwdriver to remove the five screws holding the back plate.
      • The screws are counter-clockwise threaded.
      Ask FixBot
    2. Gateway MS2285 RAM Replacement, Remove Back Plate: step 6, image 1 of 3 Gateway MS2285 RAM Replacement, Remove Back Plate: step 6, image 2 of 3 Gateway MS2285 RAM Replacement, Remove Back Plate: step 6, image 3 of 3
      • Place fingers under back plate via the indentation and lift upwards to remove.
      Ask FixBot
    3. Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: step 7, image 1 of 3 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: step 7, image 2 of 3 Gateway MS2285 RAM Replacement, Unlock Upper RAM Module: step 7, image 3 of 3
      • Push the upper RAM module's two pins outwards at the same time.
      • If done correctly, the module should have lifted.
      Ask FixBot
    4. Gateway MS2285 RAM Replacement, Remove Upper RAM Module: step 8, image 1 of 2 Gateway MS2285 RAM Replacement, Remove Upper RAM Module: step 8, image 2 of 2
      • Grab onto the module and pull away in a straight direction.
      • Do not touch the gold connectors.
      Ask FixBot
    5. Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: step 9, image 1 of 3 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: step 9, image 2 of 3 Gateway MS2285 RAM Replacement, Unlock Lower RAM Module: step 9, image 3 of 3
      • Push the lower RAM module's two pins outwards at the same time.
      Ask FixBot
    6. Gateway MS2285 RAM Replacement, Remove Lower RAM Module: step 10, image 1 of 3 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: step 10, image 2 of 3 Gateway MS2285 RAM Replacement, Remove Lower RAM Module: step 10, image 3 of 3
      • Like removing the upper module, grab the module and pull away in a straight direction.
      Ask FixBot
Author
with
Chris mello
331 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 90
All Time: 3,238
