Up to 20% off select tools
Gateway MS2285 Hard Drive Replacement
Views: 4.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
96
All Time:
4,648
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Upgrading your hard drive will allow you to store more movies, pictures and, applications on it. Also, if you add a solid-state hard drive, your boot time will decrease. Furthermore, hard drives tend to fail after long periods of time, so backing up your data and replacing your hard drive is one way to make sure your documents are safe.
    1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: step 1, image 1 of 1
      • Turn the laptop over so that the underside is facing towards you.
      Ask FixBot
    2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: step 2, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: step 2, image 2 of 2
      • Slide the short slider one towards the unlocked lock symbol.
      Ask FixBot
    3. Gateway MS2285 Hard Drive Replacement, Release The Battery: step 3, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Release The Battery: step 3, image 2 of 2
      • Slide the long slider towards the unlocked lock icon.
      • This slider is spring loaded and may require a little force.
      • If done correctly, a click will be heard and the battery will be slightly raised.
      Ask FixBot
    4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: step 4, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Remove The Battery: step 4, image 2 of 2
      • Grasp the battery's raised end and lift upwards.
      Ask FixBot
    1. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: step 5, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: step 5, image 2 of 2
      • Use the Phillips head screwdriver to remove the five screws holding the back plate.
      • The screws are counter-clockwise threaded.
      Ask FixBot
    2. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: step 6, image 1 of 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: step 6, image 2 of 3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: step 6, image 3 of 3
      • Place fingers under back plate via the indentation and lift upwards to remove.
      Ask FixBot
    3. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: step 7, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: step 7, image 2 of 2
      • Unscrew the six screws holding the hard drive cover in place
      Ask FixBot
    4. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: step 8, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: step 8, image 2 of 2
      • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
      Ask FixBot
    5. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: step 9, image 1 of 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: step 9, image 2 of 3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: step 9, image 3 of 3
      • Grip onto the black plastic tab to lift the end enough to get your fingers under.
      • Once it is high enough, place another finger or fingers under the cover and lift straight off.
      Ask FixBot
    6. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: step 10, image 1 of 2 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: step 10, image 2 of 2
      • Use hand to grab hard drive and remove.
      • Do not touch the gold connectors.
      Ask FixBot
Author
with
Chris mello
331 Reputation
3 Guides authored
UMass Dartmouth, Team 1-7, Shastany Fall 2014 Member of UMass Dartmouth, Team 1-7, Shastany Fall 2014
UMASSD-SHASTANY-F14S1G7
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 96
All Time: 4,648
