Gateway MD2614u Wireless Card Replacement
    1. Gateway MD2614u Wireless Card Replacement, Back Cover: step 1, image 1 of 1
      • Place the laptop so the back cover is facing up.
      Ask FixBot
    2. Gateway MD2614u Wireless Card Replacement: step 2, image 1 of 1
      • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
      Ask FixBot
    3. Gateway MD2614u Wireless Card Replacement: step 3, image 1 of 1
      • Lift off the cover.
      Ask FixBot
    1. Gateway MD2614u Wireless Card Replacement, Wireless Card: step 4, image 1 of 1
      • The wireless card is located to the right of the hard drive and below the RAM.
      Ask FixBot
    2. Gateway MD2614u Wireless Card Replacement: step 5, image 1 of 1
      • There are black and grey wires with gold heads attached to the top of the wireless card.
      • To remove these wires, turn the gold heads counterclockwise and pull up.
      • You will hear a snap when the heads come off.
      • It does not matter which wire you remove first, but do so one at a time.
      Ask FixBot
    3. Gateway MD2614u Wireless Card Replacement: step 6, image 1 of 1
      • Remove the two screws next to the wires with a Phillips #00 screwdriver.
      Ask FixBot
    4. Gateway MD2614u Wireless Card Replacement: step 7, image 1 of 1
      • The card will pop up 20 degrees and is loose enough to remove with your hand.
      • Carefully pull the card out to the left horizontally.
      Ask FixBot
Toni Pipes
333 Reputation
7 Guides authored
Cal Poly, Team 21-31, Regan Fall 2010 Member of Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 109
All Time: 4,919
