Up to 20% off select tools
Gateway MD2614u Key Replacement
Views: 4.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
15
Past 30 Days:
80
All Time:
4,918
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
If a key on your laptop is damaged, replacing it is a short and simple process. All you need to do is open your laptop and use your finger to pop off the key.
    1. Gateway MD2614u Key Replacement, Key: step 1, image 1 of 1
      • Place the laptop so the top cover is facing up.
      Ask FixBot
    2. Gateway MD2614u Key Replacement: step 2, image 1 of 1
      • Open the laptop with the display facing you.
      Ask FixBot
    3. Gateway MD2614u Key Replacement: step 3, image 1 of 1
      • Using your fingernail, apply pressure upward from underneath the key to pry it loose from its bearings.
      Ask FixBot
Author
with
Toni Pipes
333 Reputation
7 Guides authored
Cal Poly, Team 21-31, Regan Fall 2010 Member of Cal Poly, Team 21-31, Regan Fall 2010
CPSU-REGAN-F10S21G31
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 80
All Time: 4,918
