Up to 20% off select tools
Gateway MD2614u Internal Modem Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
82
All Time:
1,059
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Gateway MD2614u Internal Modem Replacement, Back Cover: step 1, image 1 of 1
      • Place the laptop so the back cover is facing up.
      Ask FixBot
    2. Gateway MD2614u Internal Modem Replacement: step 2, image 1 of 1
      • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
      Ask FixBot
    3. Gateway MD2614u Internal Modem Replacement: step 3, image 1 of 1
      • Lift off the cover.
      Ask FixBot
    1. Gateway MD2614u Internal Modem Replacement, Internal Modem: step 4, image 1 of 1
      • The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
      Ask FixBot
    2. Gateway MD2614u Internal Modem Replacement: step 5, image 1 of 1
      • Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
      Ask FixBot
    3. Gateway MD2614u Internal Modem Replacement: step 6, image 1 of 1
      • Carefully pry the modem as to not damage any of the surrounding components
      Ask FixBot
    4. Gateway MD2614u Internal Modem Replacement: step 7, image 1 of 1
      • Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
      Ask FixBot
    5. Gateway MD2614u Internal Modem Replacement: step 8, image 1 of 1
      • Success! You've removed the internal modem!
      Ask FixBot
Author
with
Nelson
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 82
All Time: 1,059
